Question about Acer Aspire 4720 Notebook
I just had my hard drive replaced on my Acer 4720Z and the touch pad is really sensitive. I can't figure out how to prevent the cursor from jumping every time I accidentally bump the touch pad. Is there a way to make it less sensitive?
    Brigadier General:
  • 10,406 Answers
Click Start
Click Control Panel
Use one of the tools to change the sensitivity.
Posted on May 31, 2010
My mouse pad is too sensitive, the pointer jumps, scrolls when ever i touch the pad to move the cursor. what can i do?
To change the settings on your mouse pad you should be able to go to:
1. windows Start Button
2. Control Panel
3. Hardware and Sound
4. Devices
5. Mouse
This should get you into the settings for the mouse and you can find different settings to change. Depending on your system layout of these controls they might slightly vary, but that should get you into the mouse controls so that you can change the sensitivity.
Sep 30, 2013 | Samsung RV510-A02 T3500 2.10G 320GBDVDRW...
Gateway the touch pad not function why?
Adjusting the touchpad sensitivity on a Gateway laptop lets you fix and prevent annoying touchpad problems.
Often the touchpad is accidentally brushed while typing, which causes the cursor to move out of place.
Or you may find yourself having to tap too hard or too often on the touchpad to open windows and programs.
These problems can be fixed by simply adjusting the touchpad's sensitivity settings.
Click the "Start" button and double-click "Control Panel."
Double-click "Hardware & Sound" and choose "Mouse" to open the mouse properties box.
Choose the "Device Settings" tab. Highlight "Synaptic Touchpad" in the Devices box by clicking on it. Click the "Settings" button underneath the Devices box.
Choose "Sensitivity" in the properties settings box.
Click "PalmCheck" to adjust the sensitivity of the touchpad to accidental brushes against the pad while typing, which causes the cursor to move.
Click and hold the pointer to adjust the setting on the sensitivity scale.
Click "Touch Sensitivity" to adjust the sensitivity of the touchpad to tapping.
A higher rating on the scale means less tapping pressure will be needed.
Click "OK" to save your touchpad settings.
May 15, 2013 | Acer Aspire Computers & Internet
Over sensitive touch pad
Your sensitivity might be set to high. Go to Control Panel and find the mouse icon. You should be able to adjust your settings in there somewhere.
If thats not it and the cursor is jumping around a lot, to the point you can't control it, you may have a virus.
Dec 09, 2010 | Acer Computers & Internet
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
Jumping letters on acer laptop when I type
You need to disable the touch pad while typing. During typing your palm can accidentally touch the touch pad causing the cursor to 'jump' randomly resulting in the problem.
You have not mentioned the model but on Acer laptops there's a key in the upper row with a 'pad and finger' figure on it. If the figure is in blue, press Fn together with the figure key to disable the touch pad and then again to enable it.
Mar 31, 2010 | Acer Computers & Internet
Keyboard problem- cursor keeps jumping around when I'm typing
You may be inadvertently touching the touch pad with the side of your hand or fingers as you type OR the touch pad itself is bad and needs replacement.
Jan 07, 2010 | Acer Computers & Internet
ASUS eee1000HD cursor jumps
Change the sensitivity to the touch pad in the control panel.
If you reduce the sensitivity, it should fix the problem. If not, then the top part of the laptop case needs to be opened and then below the keyboard you need to replace the touch pad.
Aug 09, 2009 | ASUS Eee PC 701 Notebook
Skipping cursor problems
i was trying to assit my lacousin with her laptop "issues" and could not figure out how to stop the cursor from skipping around. when you start typing on her laptop the cursor has been known to:
move randomly while you're typing
highlights text and deletes it
jump all over the page
After doing many google searches, I was unsuccessful in finding a solution so I thought I'd post here. I have tried to make her touch pad less sensitive but nothing seems to work.
Thanks for touching basis with me for clarification...hopes this helps!
Oct 15, 2008 | Acer Aspire 5500 5570-2609 Laptop
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Acer Aspire 4720 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
