Question about ASUS A6Km Notebook
When I am turning the PC on, the monitor is black in bios and windows mode, Using light I can see objects in monitor. Any solution? What could it be?Is it problems with inventer? Thank you.
    Guru:
  • 1,705 Answers
Yes, it probably and inverter problem. Best way to check is to connect you laptop to another monitor using the vga port (Blue) at the back and switching using the Fn keys.
If all appears well on the slave, you have an inverter problem. It could be just the connection or a faulty inverter.
To check, remove all power, battery as well.
The screen and inverter are normally connected to the mother board by multipin plugs on the end of a ribbon cable underneath the plate between the keyboard and the screen hinges.
That plate is clipped, screwed or both into place so be very careful how your remove it. Once removed make sure all multi pin plugs are home and true. If not, then you've probably repaired it. If they are then you now need someone with more expertise.
Posted on May 31, 2010
    Brigadier General:
  • 10,406 Answers
The "inverter" inside the monitor has failed.
It's about a $20 part, plus $50 to $75 for a qualified technician to disassemble the laptop, replace the part, and reassemble the laptop.
This part-replacement is *NOT* a 'do-it-yourself' project.
How do I repair my 19in LCD monitor, it receives video signal, but goes black screen?
Connect the "bad" monitor to the VGA-out port on a notebook/laptop computer, to see if it works normally when connected. If not, then the monitor is "dead".
If it works fine, check the "screen-resolution" of the computer's video-card, to see if the values exceed the capability of the monitor.
May 05, 2015 | Computers & Internet
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
The screen on my acer asire/E won't turn on even though it is powered on.
could be what they call the inverter thats gone..or your screen has gone..to find out if its your screen thats faulty just put another monitor to your laptop using a vga cable ,if your windows show on the monitor then its your laptop screen or the inverter thats gone.
Apr 20, 2014 | Acer Aspire One PC Notebook
Black screen
Follow these suggestions
- Start the computer in safe mode and run System Restore
- Removing the graphics driver in safe mode might work for you Just remove it via Device manager.
- Check for registry issues
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including black screen
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 15, 2013 | ASUS LCD Monitor
How to flash bios
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced.
Download the appropriate BIOS update and flashing utility for your motherboard from the motherboard manufacturer's website. Most manufacturer websites keep the files under a section labeled "Support." The files will likely come in a ZIP archive, so you will need to extract the files to your desktop. Copy the flashing utility and BIOS file to the DOS boot floppy. If your computer does not have a built-in floppy drive, you will need to connect a USB-type floppy drive first by plugging it into a free USB port. Rename the new BIOS image "newbios.bin" to make remembering it easy. Reboot the computer with the boot floppy in the floppy drive. Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt When the boot process is done, you will be at the "A:\" prompt. At the "A:\" prompt, run the flashing utility. For example, if the flashing utility is named "awdflash.exe," then you would type in "awdflash" and press "Enter." The flashing utility will likely have a simple graphic menu system with a list of the commands and what they do. Save an image of the existing BIOS to a file called "oldbios.bin." Once the backup is complete, point the flashing utility at the new BIOS image and start the update process. Remove the DOS floppy and reboot the computer when the update is complete.
b>
Jan 18, 2013 | Dell Inspiron Computers & Internet
I have black screen
just try to turn on your PC with f8 button safe mode option if bios window or manufacture logo comes else check lcd signal cable from motherboard
Jun 02, 2012 | Toshiba Satellite M35-S456 Notebook
My monitor comes up during start up but after 60 seconds or so it goes into sleep mode? and the monitor goes black
You might have it connected using the wrong port on the back of your computer. The monitor will display the BIOS and post messages but once it gets to windows it will turn off. The other possibility is you need to either reload the driver for your video card, change the default display device in the bios, or replace your video card.
Mar 03, 2011 | Acer AL1917W LCD Monitor
Computer screen blank
u have to need reset bios .
Open cpu cabinet and find mother bord pull cmos cell for 15 minutes from mother bord.
then bios is reset.
Tehn start computer problem still arisde.then when u power up the computer press F8 key then enter in enable vga mode.then go to dispaly property and change screen resolujtion to 1024*768 then apply and ok.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Monitor problems
wrong or incompatable display drivers.update or re install
Oct 31, 2007 | EliteGroup A530 Notebook
ASUS A6Km Notebook Logo
131 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
