Question about Magic Chef CGR3730 Gas Kitchen Range
I have a cgr3740adh and w/use oven there is strong gas smell
Whe i use the over there is a stong gas smell and takes long time for oven to heat up - getting worse and last time would not heat up so we shut it off. the top burners work fine and no gas smell when use them.
our unit is between 12-15 years old.
the serial #13864155uu and model # cgr3740adh
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Posted on Nov 25, 2008
  • 68 Answers
SOURCE: Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
Posted on May 18, 2009
SOURCE: Magic Chef oven won't light
Replaced the ignitor.
Posted on Oct 09, 2009
I am having the same problem and cannot get the pilot light to light. Now what do I do?
Posted on Apr 28, 2013
My Kenmore propane fueled gas oven gives off a powerful strong smell every time it is started. The burners on top do not. Is there any way I can correct this?
this is because the gas is on full before the oven lights
IT is an explosive situation and should be quickly corrected by an accredited gas fitter
the soot indicates an incorrect burn ratio and that will be the major part of the problem
Jan 08, 2016 | Kenmore Elite 30" Stainless Steel...
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
Strong fumes from new frigidaire gas oven.what should i look for
If it smells like gas Shut the gas off outside call installer, or
gas company. If it doesn't smell like gas, most likely it's the "new smell" caused by the heat. If you have a kitchen vent fan turn it on. If it persists Call the installer or dealer. No action by them? call the mfg customer service number in your owner's manual. It's possible something was left in the oven burner area that shouldn't be there.
Feb 27, 2015 | Frigidaire Kitchen Ranges
When i turn on my oven it smells like gas
Shut oven off & call the gas company. This is nothing to mess with. Seriously.
Nov 05, 2017 | Frigidaire FGF378AC Gas Kitchen Range
The oven sounds like it is sputtering the whole time it is preheating and baking something once it reaches it's temperature. Oven is working, just making this sound. Although, it does seems to take a...
While you didnt say if your oven is heated by gas or electric i am going to assume its gas and the cause of that sputtering sound is due to weak ingiter that is not fully opening the gas valve yet its just opening it a wee bit cauing it to basically starve for gas flow and sputtering all the time the gas is flowing. By replacing the igniter the gas will flow properly and stong and thusly the noise will cease and it will heat quickly.
If its electric heated let me know and i will figure why its sputtering
Oct 15, 2011 | Kitchen Ranges
Sometimes there is a stong smell of gas when the oven is used
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/gasoventroubleshootvideo.html this will walk you thru the correct procedure for performing this test. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Jun 25, 2010 | Maytag MGS5770 Gas Kitchen Range
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
Magic Chef CGR3730 Gas Kitchen Range Logo
85 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
