Question about Kenmore 62802 Electric Dryer
My Kenmore dryer does not get hot enough to dry a load
I have a Kenmore electric dryer model number 110-62702100. It will not dry a full load without restarting the timer at least once. It does not seem to have enough heat though it does have some. My guess is the thermostat or a heat coil. I am completely comfortable doing anything mechanical or electrical but I have never worked on a dryer so I am a little unsure where to start.
Thanks!!
  • 5,911 Answers
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust duct run to ensure you have no kinks or clogs anywhere. The following link explains many of the problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to actually overheat. Eventually, this can lead to component failures and is the source of fire hazards.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the door opening) and let me know. I hope you find this information helpful.
Posted on May 31, 2010
This is an update to my previous problem with my electric Kenmore Dryer Model #88042700. The dryer appeared to have no power. I had checked the breakers and thought the one for the dryer was on. But it...
There is a reason it's tripping..First I would have the dryer cleaned out it sound like the unit is full of lint and is holding heat also bad ventilation in dryer exhaused. If it's tripping it's electrical
hydeparkappliancerepair.com
Sep 08, 2013 | Kenmore Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Our Kenmore electric dryer does not get hot
By the nature of your question, I'm assuming the dryer IS heating, but just doesn't get hot enough. If you are experiencing longer dry times and poor drying efficiency, the following link can give you some things to check before assuming you have a malfunction with the dryer:
The number one cause of dryer heat related problems is caused by poor exhaust ventilation. If the dryer can't breathe it will not dry efficiently and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This can also become a fire hazard if not resolved. Read through the link provided and review some of the potential causes. Hopefully, this may save you a service call.
If you still have problems, please post back and let me know. I hope this helps you.
Dec 22, 2009 | Whirlpool LER5636P Electric Dryer
My dryer does not get hot enough to dry the clothes.It takes about 80 minutes to dry on high heat.
If this is an electric dryer, it would appear that you have a broken dryer element, which would account for the extended drying time.
You can access the elements from the back of the dryer by removing the rear panel. Be sure to unplug the dryer first, to avoid getting an electric shock. You will need a multi-meter to check the continuity of the two (2) dryer elements. Just put the meter into the Ohms setting and check across the two element contact points to see if you have continuity. If you find that one of them isn't giving you a zero "0" reading, that is the bad one.
Go to searsdirectparts.com to enter in your full model number and you can see the exploded line drawing for your dryer and the parts list and prices for the replacement part.
The reason the dryer is taking longer to dry, is because without both elements, the dryer cannot get hot enough to dry the clothes within the normal time, as only one element is having to provide all the heat in an attempt to dry the clothes.
You should replace the element as soon as possible, as having only one heating element working will cause that remaining element to fail sooner as well, since it will be staying one for a much longer time than normal.
Hope you find this Very Helpful and best regards!
Aug 26, 2009 | Dryers
My son has a Kenmore top load electric dryer. It
Hi, Check the door switch and the fuse. The fuse is the most common cause. You can also let the dryer cool down for an hour and see if it will restart. If it restarts, the motor might be going bad. It is hard to say without model# I'm afraid. I have not heard of a top load dryer but, these are common things to check.
Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Clothes don't dry but dryer gets hot
ck vent to outside starting and dryer back to verify vent issue try drying a load with hose disconnected
Nov 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Clothes not drying
A couple of possibilities to check. First, is the lint trap empty? If so, then the symptoms point to hot air bypassing the drum. Look for broken or misaligned plastic ducting inside the dryer itself. Check the exhaust air for moisture, as that is a better indicator than temperature. Don't forget that towels hold an enormous amount of water, & can be extremely long in drying, especially if not spun enough.
Jul 10, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 62802 Electric Dryer Logo
674 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
