Question about Refrigerators
Galaxy fridge-water leaking from under unit. no shutoff in house. water turned off at street. where do I look first to solve problem of leaking?
  • bogie1234383 May 31, 2010
    gbooze, good advice, thanks. I determined 98% that the leak is coming from the underside of a cylinder toward the front of the unit where two water lines are attached. The front of this cylinder protrudes through the removable grill.
    I traced the leak to a cylindrical plastic piece at the front of the unit where the feed comes in and another line that looks like it goes to a cylinder to delivers water to the icemaker at the back of the unit. I'd like to take this cylinder with hoses out to check more thorougly but haven't figured out the best way to do it. Help?
  • 713 Answers
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Posted on May 31, 2010
Testimonial: "Actually, gbooze's logical advice lead me to see that the leak was at the front of the unit where the intial feed attached to the (way overdue-to-be changed)water filter, which just couldn't filter anymore. Once replaced, all was well. While I had the unit out from the wall I installed an inhouse shutoff valve and cleaned places that hadn't seen soap'nwater for more than a year. "
2 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: galaxy fridge-water leaking under unit.no
Thanks for contacting Fixya.com
Check the hose under your fridge that drains condensation and such into a catch tray. Make sure the hose is draining properly.
Blow air through the tube to make sure it is not clogged. A coat hanger wire can be inserted to break up clogs. An alternative method is to use a bicycle pump to force air through the drain hole to remove any obstruction. Vacuum dust bunnies from under the fridge to allow free flow of the air. Most refrigerators periodically blow warm air across the condensation tray. The warm air dries the condensation in the tray.
Clogs are usually caused when dust, moisture and micro-organisms get together in the drain tube. Keep the dust vacuumed from the back and bottom of the fridge. Make sure the drain tube is firmly connected at all points. The drain tube can be flushed with chlorine bleach, rubbing alcohol or other anti-bacterial product. Product selection should be consistent with the tubing material.
I have searched some important instruction through net from a valuable soursse…it might be of your help…
Analyzing the likely source
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking. Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on.
Things You'll Need…
Meat Baster ,Adjustable Pliers ,Adjustable Wrench ,Soap ,Nut Driver And Socket
Replacement Parts …
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
Let us know if you have something more to know else please accept the suggestion.
Water shutoff valve
The shut off valve is part of your house. The fridge doesn't have one, so it's entirely up to whoever designed your plumbing. Could be in the wall behind the fridge, in the floor under the fridge, in the utility room downstairs, under the kitchen sink, really anywhere. I spend a lot of time hunting for them on service calls myself. They are all different, sadly. Good Luck!
Aug 25, 2013 | Sub-Zero Refrigerators
Where is the water shutoff to the waterdispenser?
It's either on the back in the water supply line before it connects to the fridge water inlet valve or under your sink where the water supply line comes from.
May 26, 2011 | Refrigerators
The refrigerator water dispenser started running without pushing the device. It won't stop unless the freezer door is open. We were just sitting in the family room and all of a sudden the dispenser...
Pull the fridge out and look behind it. You're looking for the water line that could possibly have valve shutoff. If not, follow the line back to the source. Could be tapped under the sink, could go anywhere. You are attempting to shut off water to the fridge without shutting water off to entire home. Worst case scenario is if you can't locate the fridge shutoff and you can't get it fixed today and you don't want to leave the freezer door open, locate the main water shutoff for the house and shut it off over night. Hope this helps.
Jan 26, 2011 | GE Monogram Side by Side Refrigerator
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Galaxy fridge-water leaking under unit.no shutoff in house.water turned off at street.where/how do i proceed to locate problem?
Instructions
Instructions
Instructions
Instructions
Instructions
Things You'll Need…
Replacement Parts …
Flashlight
Screwdriver
Who Can Help
Tips & Warnings
May 31, 2010 | Refrigerators
Water leak from under door
When your refer defrosts a couple times a day it produces about a quarter of a cup of water each time.This occurs in the freezer section.The water travels down a drain pipe (or tube) that leads to a drian pan in the bottom of the unit. It is collected and evaporates from the heat of the motor.
If the drain is plugged water will form inside the unit itself.If the drain tube has somehow moved and not allowing the water to collect in the drain pan it will go on the floor.Either way,if the drain is the problem the amount of water should be pretty small, no more than a cup or two.If you have an icemaker or ice and water through the door and the amount of water on the floor is more than a cup or two. I would find the water shutoff for the supply line(probably behind the unit in newer homes)and turn it off.Clean up the water and wait a day.If the water goes away assume that one of the plastic lines in the unit that carries water to the icemaker or door is leaking.If the water continues I would suspect the drain.The only way to check the drain is to unplug the unit and remove the cardboard back,locate the drain pan and see if water is present and that the drain line is in it's proper place.
If one of the water lines is leaking you will most likely need a service tech.
Also it's best to turn the icemaker off by lifting the arm or switch before you turn the water off for testing.
Mar 18, 2010 | Hotpoint HSS25GFP Side by Side...
We have water leaking from the bottom of the fridge and the ice make is not working. How do I shut the water off? Viking two door
Hi There,
You need to find the mains water supply into the house and shut it off. Or you could check the back of the fridge and see if ther is an isolating valve..Hope this helps...Please let me no
Nov 17, 2009 | Refrigerators
Refrigerators Logo
503 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
