Question about Uniden BC248CLT Base Scanner
I got a police scanner the squelch stays on all the time wont scan how do I fix that
    Genius:
  • 1,274 Answers
Try turning the squelch real slowly, most of the time its counter clockwise until it goes silent, hope this was helpful.
Posted on May 31, 2010
Squelch sound unit wont scan sound wont go away
I need to look at mine it could be a stuck monitor button or a q or chip failed . will get back with you. JR
Aug 10, 2016 | Uniden Bc340crs Bearcat 100 Channel Police...
I was given a uniden police scanner and I need to know the frequencies and how to get the static out. . Thank you . Rhonda Hansen
First thing to try is to change the "squelch" setting. If you squelch is set wrong, you will hear static all the time and the scanner may not scan. Turn the squelch until you no longer hear the static and the scanner scans.
Nov 07, 2014 | Radio Communications
What did you mean by change the squelch?
The squelch control gets rid of the hissing on a blank channel. Finda blank channel, turn up the squelch control until the hissing stops. The scanner should then scan the channels and stop on a busy one.
Jul 12, 2014 | Uniden Bearcat Scanner Bc355c 800 Mhz...
Squelch is open all the time on uniden bc350a scanner
Have you turned the squelch knob all the way in both directions, to see if that helps?
If so, then you have to replace that squelch knob unit, with a newbie.
I hope this helps.
Cheers,
Peter
Nov 02, 2012 | Uniden Bc350a Nascar Police Scanner No...
My uniden bc350a police scanner is not scanning frequencies stops on one and stays
Press manual,adjust the squelch to where it is silent,press scan. hope this helps..
Mar 20, 2010 | Uniden BC350C Base Scanner
I need to reprogram my Realistic Pro-2023 police scanner. I do not have my local police codes nor do I know how to reprogram it. Help.
PROGRAMMING YOUR SCANNER
For a a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
1. Turn on your scanner by turning VOLUME clockwise.
2. Press [MANUAL], enter the channel number you want to program, then
press [MANUAL] and [PROGRAM]. The channel number flashes to indicate
you are programming the channel.
3. Enter a frequency.
4. Press [ENTER] to store the frequency. If you make a mistake in Step
3, ERROR appears on the display. Proceed again from Step 3.
5. If you want your scanner to pause after each transmission before
scanning to the next channel, press [DELAY] so that DELAY appears in
the display. See "Using the Delay Feature."
6. To program more channels, repeat Steps 2-4. If you want to program
the next channel in sequence, simply press [PROGRAM] and repeat Steps
3 - 4.
SETTING THE VOLUME AND SQUELCH CONTROLS
Use the SQUELCH control to decrease your scanner's sensitivity to weak
signals. This allows the scanner to receive only the strongest
transmissions.
1. Turn the SQUELCH and VOLUME controls fully counterclockwise.
2. Turn the VOLUME control clockwise until you hear a hissing sound.
3. Slowly turn the SQUELCH control clockwise until the hissing sound
stops.
SCANNING THE CHANNELS
To begin scanning the channels, press [SCAN]. Your scanner scans through
all the channels except the ones you have locked out. Be sure to read the
following sections to get the full benefit from your scanner's special
features.
USING THE DELAY FEATURE
Many agencies use a two-way radio system that might have a 2 second silence
(or more) between a query and a reply. To keep from missing a reply,
program a delay on the channels you identify as operating this way.
To program a delay, select the channel and press [DELAY] so that DELAY
appears on the display. Now when your scanner pauses at an active channel
when scanning, it waits for 2 seconds after the completion of each
transmission on that channel before it resumes scanning.
If you do not want your scanner to pause, select the channel and be sure
that DELAY is not on the display. If DELAY appears on the display, press
[DELAY] to turn it off for that channel.
LOCKING OUT CHANNELS
You can make your scanner scan more efficiently by locking out channels
that you have not programmed. Manually select the channel and press [LOCK
OUT] so that LOCK OUT apperas on the display. This is also handy for
locking out channels that have a continuous transmission. You can still
manually select locked-out channels for listening.
To unlock a channel you have locked, manually select the channel and press
[LOCK OUT] so that LOCK OUT disappears from the display.
NOTE: You cannot lock out Channel 1.
USING THE PRIORITY FEATURE
Channel 1 is designated as your scanner's priority channel. You can turn
on the priority feature so that you do not miss transmissions on Channel 1,
even if you are monitoring another channel.
Press [PRIORITY] so that PRIORITY appears on the display. Now your scanner
checks Channel 1 every 2 seconds, and stays on the channel if there is any
activity.
MANUALLY SELECTING A CHANNEL
You can continuously monitor a specific channel without scanning. This is
useful if you hear an emergency broadcast on a channel and do not want to
miss any details-even though there might be periods of silence-or if you
want to monitor a specific channel.
Follow these steps to manually select a channel.
1. Press MANUAL.
2. Enter the channel number.
3. Press MANUAL again.
Or, if your scanner is scanning and stops at the desired channel, press
MANUAL one time. (Pressing MANUAL additional times causes your scanner
to step through the channels.)
LISTENING TO THE WEATHER BAND
The FCC (Federal Communications Commission) has allocated several channels
for use by the National Oceanic and Atmospheric Administration (NOAA). We
have preprogrammed your scanner with all of the frequencies available to
NOAA. To hear your local forecast and regional weather information, simply
press [WX]. Your scanner begins scanning through the weather band, and WX
SEARCH appears on the display.
Your scanner should stop within a few seconds, and you hear the local
weather broadcast. If the broadcast is weak, you can press [WX] again
to scan through the rest of the weather band.
Bill B
Feb 21, 2010 | Radio Communications
Squelch stays open
I have a problem with our photocopier sharp AR 452 U ---- codde error H5-01.
THANK YOU FOR A QUICK SOLUTION
Oct 20, 2017 | Uniden BC246T Handheld Scanner
Acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
Jan 28, 2009 | Uniden BC248CLT Base Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
Police scanner
Uniden wont admit it but it has installed faulty squelch on the 248's I had the same issue. Wont sell parts either. 60 bucks to fix.
Jul 05, 2008 | Uniden BC248CLT Base Scanner
Uniden BC248CLT Base Scanner Logo
253 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
