Question about Cameras
Canon EOS Rebel 300D: Suddenly getting error 99. Battery indicates full charge. After attempting shot battery shows half charge. Flashes but does not record picture.
  • makarlan Apr 08, 2008
    How do you do a hard reset?
  • 385 Answers
Your problem might actually be the battery. But if you've changed it already, then problem might be the memory card.
Backup your pictures and then reformat it and try again.
Also, when is the last time you cleaned out the camera, maybe it requires some cleaning.
Thanks,
Lolita
Posted on Apr 08, 2008
  • 4,889 Answers
An Error 99 signifies that the camera is having trouble communicating. It usually means an incompatible 3rd party lens or slightly dirty lens/camera contacts. (Although sometimes it seems to indicate a problem with either the lens aperture or the camera shutter.)
For an incompatible lens you have to have the manufacturer replace the electronic chip in the lens.
You can clean the contacts with a pencil eraser if you are careful (and have the lens and camera openings facing the ground when you do the cleaning so eraser crumbs don't end up in the camera).
The 'busy' error likely means a problem with the memory card. Try downloading using a card reader. If the download is successful be sure you format the card in the camera before you use it again.
It the error keeps occurring you may have to have the camera serviced.
  • eagle338
    eagle338 Apr 08, 2008
    You can press and hold the power on/off button to hold it for 10 seconds todo it.. You can also remove the battery and put it back in.. But i dont think a hard reset would fix this problem.. I Just feel that there's something wrong with the memory card..
    Master:
  • 555 Answers
The dreaded Error 99 usually means its a trip to the repair shop. Many people are frustrated by this error, but I have never seen a user-serviceable solution.
  • Matt Jurach
    Matt Jurach Apr 08, 2008
    Specifically, Error 99 refers to a problem with the lens. Lenses for this camera are chipped so that the camera body can control them.
    Error 99 means the camera cannot communicate with the lens chip, and cannot control the lens. The problem is usually with the lens, not the camera. You could try another lens to clear the error.
    If this lens has worked fine before, the chip inside it might be failing.
    Genius:
  • 1,142 Answers
Hard reset do a flea power then check the unit
  • 1 more comment
  • Anonymous Apr 08, 2008
    CF card needs to be formatted by the camera (a simple and brief procedure) in order to function properly
    Use the maximum aperture the camera works fine.
    Try using the lens at maximum aperture then close 1/3 and you get the Error 99
    Take the battery out all. then turn the camera switch on without battery that will release the static power from the cam and then u connect the battery and check for the status.
SOURCE:
Err 99 on canon eos 300d,what is it and how do I it
it is a miscellanous error and may be caused by installing a non cannon lens. Remove the battery and reinstall to see if this clears the problem
Dec 28, 2010 | Canon Digital Rebel / EOS-300D Digital...
'busy' message in view finder won't take a picture
how can you download and update firm ware when you cannot see anything on the screen?!!!!
Apr 07, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Oct 10, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
I have a new Rebel xs kit, and after 20 shots, I got the err 99. I did all the above, that is from cleaning contacts to everything possible procedure mentioned in this forum. There are few things that I...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
I hope that helps.
Aug 26, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
My 9 month old camera will power up, focus and flash however it will not take the picture. When looking through the view finder, "busy" flashes when trying to take the picture. The battery is fully charged...
I hope that helps.
Jul 31, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
I have the same problem.
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Jul 20, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Battery Drains
Be sure to charge your battery at least 15 hours to get the full power out of it. The charger light doesn't always indicate the full charge. Shop around the internet for independent repair shops. Our general repair charge is half the price you mentioned.
Oct 09, 2006 | Canon Digital Rebel / EOS-300D Digital...
Cameras Logo
111 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
