My blackberry didnt get wet exactly maybe the steam got into it so i took the battery out and put the blow dryer on it, it was working okay but then it started short circeting on me, it wud stop then it would start again, my track button wont click and it's texting and calling everyone in my phonebook, i dont even have to click on anything as soon as the trackball goes over an icon it automatically clicks on the icon and starts doing its own thing, i just put it in a bag of dried rice will it fix it? i hope i didnt damage anything with the blow dryer and if i did is it fixable? please help me asap the black berry really is a crackberry and i feel like im in detox! thank you -Nikki
  • 4,102 Answers
HI, the chances of the bag of rice doing anything is pretty slim, wht you should have done is left the battery out for a day or two to ensure the circuit board had dried out properly, then their may have been some slim chance of it working, now thats the bad news, as for the good, their isnt much good news im afraid.
Give the bag of rice a go, i know what your trying to do by using the rice, your trying to draw ouw any damp out of the phone, but the problem is the phone has more thant likely dried out completely and when it has dried it has corroded where the buttons press on the circuit board causing a short, whitch is why the buttons are pressing on their own.
The good news is your bb switches on and is working so that is the good news, how ever to get the contacts sorted out for the buttons and track ball your going to need to take your blackberry into a phone shop and ask them to give it a good clean for you, the phone shop have a product called flux that will clean all the corrosion off the circuit board contacts and you should find this will solve your problem.
It sounds to me like you wont need any parts that it unless your speaker or mic no longer work, as the rest of the phone works you should be ok and should get away with just having someone clean it properly for you.
their will be a small charge for this and it will solve your problem so give the rice a couple of hours and if by some small miracle it works then you should have no problems how ever the chances are your going to have the same problem. So find yourself a small independant phone shop as these will charge you a lot less than bigger well known shops, tell them your problem and say you have been told that it should work as long as the contacts on the board have been cleaned.
Once you have had it cleaned it will be working and you can use it as normal,if the rice makes no difference then leave the phone off as the chances are you could short something out if you leave it on for to long and this could destroy the phone or cost you a fortune in parts and labour charges.
Im sorry their is no simple fix for your blackberry but it is going to be a case of a good internal clean of the circuit board and contacts and then your bb should be back to normal and in your hands again, giving you your daily bb fix again,lol
let me know if you need further advice or help ok and ill do my best to assist you further ok
Posted on May 31, 2010
My whirlpool duet steam dryer appears to be stuck on the steam cycle. I put in a load of clothes that were barely wet and now they are soaking wet. The heating element is working but they are still...
Hello, Thank You for using FixYa. I will be helping you today.It can be a stuck relay to the water valve or a water valve that is not closing all the way. Put a towel across the bottom of the drum a few hours and see if it gets wet when the unit is not in use if so the valve is stuck open and needs to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 27, 2011 | Dryers
Hello....my tumble dryer was working perfect until my son decided to put soaking wet washing into it....and i mean soaking wet....now the drum doesnt turn but the heat still comes out....please help as...
did the belt come off due to heavy load? if it is still n and didnt blow a breaker it may have blew the motor, you would have to take the back off to inspect, dont forget to unplug first
Jan 18, 2011 | Dryers
I think that my blackberry cuve may have a little bit of water damage because someone spilled a drink on it last night. I took the battery out and put it back in and the phone comes on and the messages are...
First, to check if there is water damage inside the phone, you can check the water mark sticker.
When you take the back piece off your phone, on the left of the battery inside a rectangle shaped cut-out in the plastic, you will see a little square. If it is red/pink this means there is definitely water damage, if its white then no water has reached that part of your phone. Unfortunately if its turned red or pink Blackberry will not repair it free of charge.
That being said, you can try completely submerging your phone in a bowl of rice. This will draw the moisture out and hopefully get your phone in working condition again, this has worked for myself and many friends.
Nov 07, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
I was in heavy rain and my phone got wet. I took the battery out and let everything dry. everything works except for touch screen
The digitizer maybe bad. You may want to leave it out without the battery in. use a blow dryer but do not heat it up it will crack the screen. If that doesn't dry the screen out then the digitizer will have to be replaced. hope this helps.
Oct 23, 2010 | LG Vu CU920 Cellular Phone
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
I put a new radio in my car and now it wont start 1190 toyota
Did you in stall it your self ? if so make sure you didnt blow fuses and check the connections make sure you are getting power and if you put subs and power amp and stuff like that make sure you have enough battery power to power everything if not the car wont even turn at all cuz the juice is working on its own to start the radio. check also you didnt cut any wires while doing so and if you didnt install it your self and took it in then take it back something went wrong maybe....
Dec 02, 2009 | 2001 Chevrolet Venture
I have the same exact problem.
on the Blackberry if you have a problem with it malfunctioning, just remove the battery and put it back in after a few seconds and the phone will reboot. This is how you reset most smartphones.
Jul 15, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Screen doesnt work
if you have a screwdriver, you can open the phone up and check if it is still dry or wet and also look to see if there are any burnout marks (greeny-blue or white).air it for an hour or few and put it back together. try again. is it pos 5 or pos 6 bit. or is it tork 5 or 6, at jay=car or dicks or bunnings if you don't need advice on it.
May 30, 2009 | Lands Phones
LG PHONE STUCK ON EMERGENCY DOWNLOAD
I had the same problem!! This might help: 1. Take out the battery, SIM card, and memory card (if applicable). 2. Let the phone sit in the sun for a couple of days. 3. Put the SIM card back in the phone and plug the phone charger into the phone. 4. When prompted, insert the battery into the phone 5. When battery is fully charged, remove the charger and depress the call button simultaneously.
I tired this and the phone is now working!!! Also, I do not seem to have lost any of the features!
Good Luck!!!
Jan 27, 2009 | LG Vu CU920 Cellular Phone
Wet motorola l6
okay...you should purchase a new keyboard that should help.
Dec 18, 2007 | Motorola Mobility L6 Cellular Phone
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
