Question about VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard
Can you guys assist with the burned off contact on the RAM slot and can i only use one slot if i get my computer to beep and monitor to work?
  • soultru Jun 09, 2010
    I have changed ram, cpu,psu and used all you guys suggestions still no beep, no signal. What an i try next?
  • soultru Jun 29, 2010
    Yes i have tried other ram but with no luck, i do not receive any beeps at all.
    Genius:
  • 1,354 Answers
Hi
if your getting only beep from the motherboard it meance your RAM is not Supporting with your Motherbard
you have try with right RAM wich supports your motherbard
Posted on Jun 09, 2010
  • soultru Jun 11, 2010
    Yes, i also do not get a beep too. Do you have any other options? I also noticed that there is no light on the motherboard too although it is on.
    I am rejecting your current solution.
  • 857 Answers
There are two or more slots present to install ram on the motherboard.
It doesnot matter how many slots you are using to install ram just keep this in mind that the amount of ram which you are putting in must be supported by your PC.
Hence you can use one slot to install ram.
Posted on Jun 02, 2010
  • 1 more comment
  • soultru Jun 07, 2010
    I have almost given up hope of fixing the problem as all solutions given has not helped so far.
  • soultru Jun 08, 2010
    Hi is it possible to assist with more solutions?
Cpu was working fine. stopped working of a sudden. turned off & on. 4 long beep, pause, followed by 2 beeps. number 3,4 come out on actual computer. nothing shows up on monitor. please help.
please check your ram is properly inserted if please remove your ram and insert it properly in slot before inserting in slot clean the slot and rub the ram strings with eraser and insert it. if ur using with 2 rams in 2 slot please remove one of the ram from cpu and check if problem persits again remove another ram from cpu
Sep 07, 2015 | Computers & Internet
I start my computer up and i get 3 beeps and a black screen!
Three beep usually mean there is a ram issue. The computer is not passing the post. To resolve this issue I would first try to reseat the ram. Basiclly you will remove the Ram and place it back in the same slot. If this fail, place the ram in another slot.
Jul 11, 2011 | Computers & Internet
I'm having an aspire m5640. it does not boot. beep?
Yes if there are error on the system you should most likely hear a beep most of the time when there is no beep it is due to bad ram. Some times beep codes can't detect bad ram and your computer will not boot.
Open the computer up and see how many ram chips you have if you have more than one take the one in dimm slot 2 out. There should be small writing next to the slots 1,2,3,4 or Dim 1 dim 2 ect ect. you always want to keep slot 1 with ram so start by pulling out the ram out of slot 2 and turn your computer on. If your computer still dosn't post pull the ram out of slot 1 out and insert the ram that was in slot 2 into slot 1 if still no luck it's most likely your board but the best way to test this is to know that you have a good working stick of ram you could purchase one and if it dosnt work bring it back ... theres also the chance of your video card being bad but there is usualy a post code for it (beep code)
if you have no clue on what ram looks or how to open your computer just google for installing ram on a computer and you should find step by step guides
Jun 02, 2010 | Acer Aspire m5640 PC Desktop
I started my HP computer today and it starting beeping, the tower and monitor have power to them, but the display isn't showing up on the monitor, it's just black
You need to open the tower and reset the memory sticks still if you get those beeps then try those memory stick one by one or swap the memory stick
Regards
Samson Ved
Dec 03, 2008 | HP Pavilion xl756 (P1358A#888) PC Desktop
Please help
check mosfet ic 7338 it's burn in near by pin no1 replace it
check serial bank registance all near by ram slot value is 10ohms
Mar 29, 2008 | Intel D845GVSR Motherboard
Cannot turn PC on after change RAM
try other combination with the ram, switch their slots, etc. try cleaning slots contacts, make sure it's seated well.
try resetting the bios with the jumper.
Mar 08, 2008 | Computers & Internet
Tower Beeping
As I can see the problem is not monitor but your PC if computer chasis beeping, depends on number of beeps the problem can be VGA card one long beep and 3 short or RAM if it beeping one by one short beep and finaly CPU if it continuosly beeps like police sirene. If beeps are pointing to VGA or RAM you must open computer chasis and plug out VGA and RAM and clean dust out of slots and of VGA card and RAM as well with painbrush and vacum cleaner and plug them back.
Dec 12, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
PC beeping, monitor will not display
we have different sound we can hear in cases of hardware problem, once the video card has loose contact it also beep continously, a beep sound also occurs when the ram(memory card) loose contact, one beep sound when it boot clearly it proceeds as go signal going to operating system. if you are using an upgraded video card remove temporarily and use the on-board from your motherboard. in case that it won't boot and still you hear a beep, beep ,sound then, switch-off the power take out the memory card clean the contact points(bronze color) with pencil eraser, make sure that no remaining residues of eraser remained before you install to the slot. i hope that this solves your problem
Dec 01, 2007 | Computers & Internet
VIA ECS PM800-M2 PM800 P4FSB 800 Supports Intel Pentium 4 Processor (REV:1.0) (ECSPM800M2V10) Motherboard Logo
Top VIA Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a VIA Computer and Internet Expert? Answer questions, earn points and help others
