Question about Garden
Ihave a Toro hand mower with a Tecumseh engine, was running fine until couple days ago. Wont stay running, unless you keep pushing the primer button. Starts ok, but not getting steady fuel flow.
  • 177 Answers
Carby service required
Posted on Jun 07, 2010
Toro 6.5 HP Self propelled walk behind 22
take the top cover off the engine. you will see the coil on top there. unplug the wire that plugs into it. put the cover back on and try to start it. if it starts it is not the coil. try a different spark plug first. pull the cord with the plug out to get all the gas out of the engine.
Mar 20, 2017 | Garden
Mower wont stay run n unless i hold primer in
If it is a float bowl carburetor may have a jet clogged or the primer bulb could have a hole in it. If it is a diaphragm type carburetor, the diaphragm may be stiff and needs replacing. Check it out.
Good day.
Nov 07, 2009 | Toro Garden
I have a 3 yr. old toro, It wont stay running.
You probably have a crack or hole in the primer bulb. Replace it and see if that solves your problem.
Sep 20, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Toro lawm mower
the bulb is allowing air in some where. Replace it.
Jul 20, 2009 | Toro Lawn Mower With Toro Power Tools
My Toro lawn mower (Tecumseh engine) is quitting on me.
defective check valve pull the tank and remove the fuel line replace the small inline filter on hose.
May 24, 2009 | Garden
SMALL ENGINE PROBLEM
Carb will need to removed and thouroughly cleaned.
Also you can file or clean coil where the contacts rub on flywheel.
Change your spark plug as well.
May 13, 2009 | Garden
Mower will not stay running unless primer button continuouly pushed. Gas seems to not be independently flowing, requires manual priming to stay running. As soon as primer gas used, will stop running.
The tube in the bottom of the carb. is probably clogged. Remove the carb, and bowl and try spraying WD-40 through the tube, it should spray into the venturi if it doesn't try using a tip cleaner to unclog the tube.
Apr 12, 2009 | Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
301 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
