Question about Garmin Nuvi 465T Car GPS Receiver
Cannot calculate the route - Garmin Nuvi 465T Car GPS Receiver
Why is the navigation not re-calculate route
Your still under factory warranty so take it back to the dealership.
Aug 04, 2014 | 2014 Toyota Highlander
HOW I FIX THE MESSAGE I GET WHEN I HIT NAVIGATE - ROUTE CALCULATION FAILED
Doy you get that message always, or only when you are inside a building or close to very tall buildings?
Make sure your device has a clear view to open sky, so it can find enough satellites, to calculate where it is. And if this happens, give the device enough time to find out. It could take up to one or 2 minutes before it is ready.
Jun 03, 2014 | Navigon 2100 Max Portable GPS System
What 2014 highlander problems have been found so far?
My navigation did not re-calculate the route, when I missed a turn.
I went to the dealer, they said it is working fine. I said all GPS re-calculate the route when one miss a turn. They argued that nothing they can do about it. All Toyota navigation work the same.
May 20, 2014 | 2014 Toyota Highlander
Cannot Calculate the route - Garmin Nuvi 3760
My probleme:
When you want to select (established) a route (Finding Location or Planing a Trip) the device machine can not calculate route and displays the following message: "Route waypoint memory is full". The device is Garmin 3760T.
I found the solution:
1. Start the device.
2. Touch "Wiew Map or Map"
3. Touch on bottom right of screen (Speed)
4. Hold your finger on top center of screen for 5-10 seconds (the speed semicircle between Trip A and Trip B). The unit would go into "Diagnostic Page".
5. Select "Clear all user data" and confirm.
Warning: will erase all user-selected data (Home, Recently Found, Favorites, Trip Planner, ....).
Mar 04, 2014 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
Garmin Nuvi 760 gps Unable to calculate route No roads near starting point
I have same issue Garmin Nuvi 760 gps Unable to calculate route No roads near starting point started this morning. Has worked fine for 2 years till today. David W
Aug 02, 2010 | Garmin Nuvi 660 GPS Receiver
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Garmin Nuvi Unable to calculate route No roads near starting poin
Its a problem you need to address with Garmin on this model before warranty runs out
Please rate our help to keep the FREE service onlinew++++Thank you for using FIXYA
Sep 11, 2009 | Garmin nuvi 350 GPS Receiver
The nuvi 500 loaded with garmap 2009. Route calculation problem
good day sir
have tou dun a firmware update on the unit
if you have done so can you please send a copy of the route to me please
Werner Trollip
Technical
wernert@garmin.co.za www.garmin.co.za
Office: +27 11 251 9999
DIR +27 11 251 9956
Fax: +27 86 544 3972
Jun 05, 2009 | Garmin nuvi 500 GPS Receiver
Route calculation Error on Garmin GPSmap 60CSx
Try re-setting your gps by simultaneously pressing the Enter and Page buttons while turning it on if that doesn't work check your firmware i found the latest one v 3.90 would shut off my gps when recalculating v 3.70 is stable Garmin know that the new firmware can cause problems
Mar 09, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Garmin Nuvi 465T Car GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
