Question about Nintendo Wii Console
Second remote will not activate. batteries changed.
  • 73 Answers
Take the battery cover off the wii controller and press the red button. then open the cover at the front of the wii and press the red button. do this when you are at the wii menu. this registeres the remote
Posted on Jun 29, 2010
Power lock remote on 2007 forenza not working
Check the light on the remote fob. Does it light up when you press the button? It will light for only a part of a second.
Sometimes the transmitter stops working for no reason and there is no repair, you have to buy a new remote fob, or in the case of some vehicles, you have to buy a new key and have the agents activate the key, then you can activate the remote with a special procedure.
Mar 08, 2015 | 2007 Suzuki Forenza
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
Remote lock and trunk stopped working
Have you tried replacing the fuse?
Jun 07, 2014 | 2003 Chevrolet Impala
Remote start problems
get the battery changed or checked or proper voltage..may be too low on cold start..should read 12.8 or higher..
Dec 21, 2013 | 2007 Lincoln MKX AWD
Can't get my second remote to activate, and so only one player mode works.
It seems your second remote has malfunctioned. There are 2 options at this point.
1.) Replace the batteries and see what happens.
2.) Send it in for a replacement controller (if under warranty)
I hope I helped!
Apr 12, 2010 | Nintendo Wii Console
Can not activate second controller on NCAA 09 and Guitar Hero
ress the red button inside the battery cover of the wii remote, then press the red button inside the cover at the front of the wii. do this at the wii menu to register remote 2
Jan 20, 2009 | Nintendo Wii Console
Chamberlain 1/2 hp Model # 82000 remotes not working
get a referral to a garage door guy! First off, make sure you have not activated "Lock" on console. If not, recode remote by hitting LEARN button on motor for 1 second and pusjing a button on remote. Light bulb on motor should blink 2x. Repeat for each remote you are having problem with. Should do it.
Jan 14, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remote key fob will not work-battery replaced
VW/AUDI/SEAT/SKODA
Remote Control Programming (1997 ON)
Procedure
1. Switch Ignition ON and leave the key in the ignition.
2. Mechanically lock the vehicle using the Drivers door using a second
key.
3. Using the remote control press the Unlock button once, and the horn
will sound once.
4. Wait 6 seconds and press the unlock button once to activate the coding
procedure. The remote control will now be programmed.
NOTE : When performing programming on additional remotes the procedure
is the same, except you press the unlock button 2, 3 or 4 times for the
different remote.
For example : If programming 2 remotes press the unlock button twice with
a 1 second interval between each press, repeat for 3 and 4 remotes.
5. Switch Ignition OFF.
6. Remove key from ignition and check for operation.
7. The coding procedure can be repeated up to 4 times for additional remotes.
8. The ignition must be switched OFF between programming each remote
control.
Remote Control Erasing (1997 ON)
Procedure
key.
3. Press the remote control unlock button 5 times in 1 second intervals.
A short horn will sound.
4. Wait 6 seconds and press the unlock button once to activate memory
erase.
5. Switch ignition OFF, all remotes are now erased.
Dec 24, 2008 | 2004 Volkswagen New Beetle Convertible
Mutli purpose TV control
To add or remove an Activity, click Add an Activity or Remove an Activity.
• To customize an Activity, click Customize next to an Activity icon, and then click the appropriate
option.
• To change the names of Activities click Customize next to the Activity icon, and then click
Rename Activity name.
• To have more than one Activity of a given type (e.g. If you have both a cable converter and a
satellite receiver, you can add a second Watch Television Activity) click Add an Activity. When
you're done, rename the Activities to help you distinguish between them (e.g. For the Watch
Television Activity you could rename one "Watch Television" to "Watch Cable" and the other to
"Watch Satellite
Dec 12, 2008 | Logitech Harmony 880 LCD Remote Control
Central locking not working on key.
Before you spend bigger amount, check the battery in the key. Usually a CR2032 battery can be find there. (Open the Keyfob by inserting an object into the key ring holder and pulling the top and bottom apart, Seperate the two halfs, Open the top half to expose the battery... )
Nov 28, 2008 | 1998 Audi A6
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
