Question about Microsoft Computers & Internet
HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
    Champion:
  • Microsoft Expert
  • 410 Answers
In such case I would suggest programmed method You may try next one DBF Repair Toolbox software repairs database files starting with Windows 98
Posted on Jun 16, 2012
2 Suggested Answers
varun_engr
  • 516 Answers
SOURCE: HOW TO SOLVE VFP FILE CURRUPT WHEN POWER FAILURE
At times, you may view that your MS Visual FoxPro 9.0 database is behaving abnormally. Some of the abnormal symptoms could be an error message while opening any database table, invalid characters in place of pre-defined values, and and more. The main reason for abnormal behavior of the database is its corruption due some logical crash. Few common reasons for corruption of MS Visual FoxPro 9.0 database are abnormal termination, faulty network devices, simultaneous modifications, conflicting third-party software, and incompatible service packs.
To overcome such database corruption scenarios, the user can use an up-to-date backup and perform restoration. However, restoration fails in cases where the user either forgets to create a database or the database backup itself gets damaged. In such cases, the database users can use a third-party DBF File Repair application to repair his/her corrupted database.
To illustrate the above case, consider a real-time scenario wherein you execute a query to modify your MS Visual FoxPro 9.0 database. While the query was performing the modification, the system shutdown due to power failure. However, the next time you tried to mount the database, you encountered an error message that did not allow you to access the database records. Moreover, the same error message appears every time you try to access the database.
Cause:
The root cause for the error message is MS Visual FoxPro 9.0 database corruption due to improper system shutdown.
Resolution:
The database corruption error message can be surmounted by following the below steps:
Use a complete database backup and perform restoration. However, in case of database backup unavailability, you will need to search for a commercial DBF File Repair utility.
A third-party DBF Repair application uses effective repair techniques to repair logically damaged MS Visual FoxPro 9.0 database and restore it at a new and safe location. The original database during the repair process remains intact. The tool is easy-to-understand and allows even a non-technical person to perform repair.
DBF Recovery Software is a comprehensive solution to repair databases created in MS Visual FoxPro 9.0, MS Visual FoxPro 8.0, and MS Visual FoxPro 7.0. The tool also repairs databases built in dBase III, dBase IV, and dBase V. Supported by Windows 7, Vista, 2003, XP, and 2000, the DBF Repair tool creates a new repaired file that can be attached to existing database.
Tanvi Sharma is a self employed Internet entrepreneur and product reviewer. This DBF Repair utility is extremely useful when the dBase and Foxpro database gets corrupted due to internal program errors, hardware malfunctioning, accidental deletion of data and more. This DBF Repair software repairs all types of database components including table name, column name, column data type, indexes and primary keys.
Posted on May 31, 2010
How to fix corrupted Visual FoxPro 9 dbf, dbc?
"Not a table" means more serious problem than TABLEVALIDATE can fix obviously. Also when DBF recovery fails the problem can be critical (if you have the DBF recovery which supports your DBF file format).
You should look at the DBF header via some hexa editor. You may even use the one from VFP:
DO HOME() + "Tools\HexEdit\HexEdit.app"
It will ask for a file opening so please select your DBF and post first two lines here or look at the DBF structure description in the VFP help.
First two lines (in hex editor) contain the file type, number of records, record size, last update etc. "Not a table" means the first byte was not recognized as valid DBF file marker.
Additional lines contain column descriptions each one in 16 bytes.
More info: http://msdn.microsoft.com/en-us/library/st4a0s68(v=vs.80).aspx
Second easiest fix is use DBF Recovery Toolbox or some other applications. Search in Google. http://www.oemailrecovery.com/dbf_recovery.html
Jan 17, 2016 | Microsoft Visual FoxPro 9.0 Professional...
Printer Command using VFP
Greetings
Install Bartender software,seagul printer driver.
Design your label.
Print the label to file.
Use the file to embed in vfp (increment the variable i.e. the one printing 18...)
Buzz me at 9344104232, mmi.mdu@gmail.com
M. Murali
Feb 10, 2015 | Argox Office Equipment & Supplies
Cause:
Resolution:
May 31, 2010 | Microsoft Visual FoxPro Professional...
My font size increases when i am using my desktop making it impossible to use. Do I have a virus?
it may be the virus issue or it maybe the OS file currupt issue, try to reload the OS, it will solve the problem
Jan 10, 2010 | Dell Inspiron 6000 Notebook
Themes currupt except default.
Your theme is corrupt.... You can do any of the following;
1. Download the Nokia PC Suit from Nokia
2. After running the Nokia PC suite on your PC, then open the application and launch it. From the Nokia PC Suite application back up all the information you have on your phone. This could take about 45 minutes.
3. Using the PC Suite locate update Phone Software. Once you do this you'll have a browser open up. Download the update from that page. Save it somewhere in your computer.
4. After download is complete you can now proceed to update your phone.
Upon completion you'll have your theme fixed.
Good Luck
Sep 30, 2009 | Nokia E71 Smartphone
Create access mdb file by vfp code
Try this
#define dbLogical 1
#define dbNumber 2
#define dbInteger 3
#define dbLongInteger 4
#define dbCurrency 5
#define dbSingle 6
#define dbDouble 7
#define dbDateTime 8
#define dbBinary 9
#define dbText 10
#define dbOLEObject 11
#define dbMemo 12
#define dbReplication 15
#define dbDecimal 16
if file("C:\accesstest.mdb")
delete file c:\accesstest.mdb
endif
public oAccess
oAccess = createobject("Access.application")
oAccess.visible= .t.
newMDB = oAccess.NewCurrentDatabase("C:\accesstest")
newtable = oAccess.CurrentDb.CreateTableDef('testtable')
with newtable
.fields.append(.CreateField("Field1", dbLogical))
.fields.append(.CreateField("Field2", dbNumber))
.fields.append(.CreateField("Field3", dbInteger))
endwith
oAccess.CurrentDb.TableDefs.append( newtable)
dbc2Convert = "\\tpdfiles\data\dfreeman\tip\data\rta\rta"
open database (dbc2convert)
dbgetprop(rta,"table",)
After it runs you will need to close the MDB and reopen it.
Oct 15, 2008 | Microsoft Computers & Internet
File currupt
you can reload the operating system by pressing alt+F10 during boot. (if you still have recovery partition on your harddrive).
if you already deleted recovery partition from your harddrive, the only option is installing OS from cd.
Jul 10, 2008 | Acer Aspire 5500 5570-2609 Laptop
How can i repair my currupt file
lower capacity pc can slower the system specially xp or vista. try to reformat your pc and try to install win98 os for you to diffenciate the speed between higher os.
Sep 25, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
