Question about Asko D1706 Built-in Dishwasher
Water in the bottom at the end of the cycle
The dishwasher works fine, but when the cycle ends, about one inch of water remains in the bottom. The problem originated about a week ago, after the door was opened during the normal washing cycle. We are still using the dishwasher, but I have to fiddle with the control knob to have the bottom drained.
    Sergeant:
  • 351 Answers
Check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
Posted on Jun 02, 2010
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
The unit runs through cycle fine, but ends with water remaining in the bottom, that has not been drained and dishes are covered with soap residue.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Dec 16, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
KUDIO1IL8L6 Kithenaide dishwasher. Water remains in bottom of dishwasher about 1 inch deep afeter all cycles are complete. I have checked to see if it drains and it does twice although it seems slow to me....
You have a restriction in the return of the unit. This also leads to sanitation issues. Pull the bottom basket, remove the lower arm and using a screw driver, remove the return cover. Clean out any obstruction and reassemble. If you are still having problems, your pump may be worn to the point it will not remove all the water at the end of the cycle.
Oct 03, 2009 | KitchenAid Dishwashers
Some water remain in bottom
In The Manual It States That There is supposed to be some to keep the seals Lubricated. It is normal
Sep 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water at end of cycle
It is normal for a small amount of water to remain after each loadof dishes is cleaned.
Is the water clear or cloudy?
Is there an odor?
How deep is the water? Less the two inches?
Post back with your findings here. OK?
Apr 16, 2009 | Dishwashers
Water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water won't pump out at end of cycle
there could be a block in the outlet pipe
regards
and please rate us
Nov 28, 2008 | Kenmore 24 in. 17039 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
442 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
