Question about Pelonis Heating & Cooling
When you turn the unit on, the red light "full" is on, and didn't allow the A/C to work, just the fan. We checked the container supposed to be full and it is empty and dry. Could be some kind of sensor not working?. Should be some button or switch we nedd to press?. Please, help us. Thanks..Ramon Castillo
  • 8,404 Answers
Is this a portable device? I think so ... you say it has a container, presumably for condensate. Yes, there is a sensor that may be faulty or you may just not have the bucket in the device properly. Jiggle it around before you do anything.
No luck, look inside the container port ... there will be a switch somewhere that the bucket presses against when the container is full of water. It will not run without the container. Said slightly differently, the switch I am talking about must be in the closed position to allow the machine to run. When the water fills the bucket, the container shifts position and turns the machine off.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
  • rcrkerygma May 31, 2010
    Thanks. I checked the container. The bucket, once full it suppses to raise at the end and with a part that is protruded to hit some switch inside the unit. But i look into the unit and at the end, where theswitch is suppossed to be, there is a hole. Maybe the switch is missing. What can I do then?
    Ramon
  • A Miller May 31, 2010
    It may have been pressed up inside the machine ... you are on the right track ... keep looking.
    Thanks for the feedback.
Saeco coffee machine with a red blinking exclamation point light won't make coffee, how do I fix it?
When the red exclamation point is flashing slow, something is not where it is supposed to be, bean hopper lid, door, brew mech, water tank empty, dregs box or water tray on dregs container is full. If the red exclamation point is flashing quickly, open the steam valve for pump priming. If pump turns on, and water passes correctly, the light should go off and return to heating stage. If not, we have a blockage or a pump that is not working correctly.
Nov 16, 2015 | Saeco Odea Giro Plus Coffee Maker
What is the red light next to the green power light? It appears to look like a temperature light. My unit won't run.
In most cases it means the shredder is full or something is jammed. Empty the shredding container. If the machine has a "reverse" position on its switch, try running it backwards to get whatever is jamming the teeth to come back out.
Nov 03, 2014 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Has been running fine. my daughter emptied it yesterday morning and didn't put the catch container back in the machine properly and a red light (small round) on top left of machine was on when I went...
Actually, the fan shouldn't be working if the water bucket is not installed properly. So, I believe it's more of a case of the electronic controls need to be reset.
To accomplish this, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 minutes.
After the time as elapsed, plug the unit in and turn the Master ON/OFF Switch to ON. The Bucket Full light should not, now be ON. And the unit can function as it should, after you reset the controls for maximum humidity extraction (32 - 35%).
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 13, 2011 | Danby DDR586R Dehumidifier
Got a new lamp tv works great but wen I turn it off it has a very quiet hum is this normal also wen I turn it off the.red.light blonks green for a while befor eventualy going away what dose this mean...
Hello; The noise when turning set off is likely the fan that cools the lamp down gradually. The lamp can crack if the fan does not work. Dust in the fan can also add to the noise. When the set is turned on, the microcomputer watches the lamp come up to full brightness and shows this with the LED colors. All lamps containing mercury take time to get up to full brightness.This also applies to mercury compact florescent lamps, yard lights, and even neon signs that contain mercury.
Jun 07, 2011 | Toshiba 52HM95 52" HDTV Projection...
Green "ice size" light is
try to reset your unit to unplug the unit then after a several minutes plug it on then observe the unit.
Mar 06, 2011 | Refrigerators
Three rings are green one red on tv says error e73
Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
Thank you
Jun 04, 2010 | Microsoft Xbox 360 Console
My lg 30 is not working.
It is supposed to. There is a float that rises as the container fills. When the container is filled to capacity, the float is at its highest point and the humidfier turns off. At the same time, the red light comes on. This is normal. When you remove the container, the red light stays on b/c the float is still at its highest position. It is designed to do this so the humidifier doesn't run when the container is not installed. If the light does not turn off after you replace the container, give the humidifier a tap to move the float back.
Jan 12, 2009 | LG DH30 GoldStar Dehumidifier
M7DH45B2A Dehumidifier
The fall may have knocked out some wiring -- open the unit (remove back panel, then remove front by taking out screws inside) and see if any of the cables to the front panel or control board came out.
Jun 20, 2008 | Maytag M7DH45B2A Dehumidifier
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Heating & Cooling Logo
35 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
