Question about Frigidaire GLEQ2152ES Electric Dryer
Dryer drum is scraping against something and making a thumping noise as it spins
  • Frigidaire Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Problem 1... Your scraping noise is probably coming from the drum rubbing the door as it rotates, you door seal may need replacement.
Problem 2...Your other problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Posted on May 31, 2010
Hearing a scraping noise (metal against metal) in dryer- how do I remove the door
it is also possible that a metal support bar from a woman's bra found its way between the drum and the panel, just reach with your hand or with a hooked coat hanger and turn around the seal of the drum,
Aug 01, 2015 | Dryers
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
My dryer MAKES A lOUD THUMPING NOISE IN THE DRUM. BELTS ARE NOT BROKE
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Oct 05, 2014 | Dryers
GE dryer DCVH515EFOWW thumping noise after heats up. Recently replaced front drum bearing and slides which fixed squeaking. Now having rhythmic thumping (no squeal or squeak).
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Aug 18, 2014 | Dryers
Scraping, thumping, and whining sound as the washer drum spins. sounds like something may be loose inside. sounds like a loose belt squeeling?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 19, 2011 | Frigidaire Washing Machines
Dryer works, but makes noise.
There are a lot of moving part that can cause noises or vibration when get worn out.
  • Make sure dryer is level, and on a secure floor, and that nothing is leaning against the dryer.
  • Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a squeak.
  • Check for foreign objects below the lint filter:-Remove lint filter, and look down opening. If you need to stick your hand down the opening to remove an object, be careful because the edges could be sharp. It would be advisable for you to wear a pair of work gloves.
  • Foreign objects in the drum front seal and worn or loose drum slides can cause a metal scraping noise as the drum rotates.
  • Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
  • A frayed or damaged belt will make a thumping sound.
It is normal to hear the sound of the drum as it turns. If your dryer is making unusual noises and the above suggestions do not resolve the situation, discontinue use of the dryer until it has been checked by a qualified servicer. Continued use may cause wear of other parts making the repair more costly.
Thanks..!!
Sep 19, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer is heating but drum making very loud noise like scraping against something
next time send model number,check the glides on the front bulkhead that the drum rides on,also check the pulley and rollers while your in there and check the blower wheel,make sure it isn't cracked or loose scraping against the housing
Jan 31, 2010 | Amana Dryers
My GE Profile DPSE810 Electic Dryer has started making a scraping noise when the drum rotates. What could be causing the scraping? It makes the noise even if I take out all the clothes and there is nothing...
Told by several GE Service Techs that the noise is normal metal expansion & nothing can be done. Anyone else have this issue?
First dryer in over 40 years we ever heard this type of noise.
Jul 05, 2009 | GE Profile Harmony DPGT750EC Electric...
Fridgedaire drying- It's screeching!
There are several things that will make a dryer noisy. Here's a list of a few items that I know of. Some may or may not apply to your dryer: FIRST OF ALL, BEFORE SERVICING THE INSIDE OF ANY DRYER UNPLUG THE UNIT OR TURN THE CIRCUIT BREAKER OFF. 1. Drum rollers worn out. Most dryers have some sort of drum roller that supports the dryer drum. There are two mounted under the drum in the rear of the dryer. Some models will have an additional set of drum rollers under the front of the drum as well. You may also here the drum thumping too. Lubricating them with a good quality turbine oil at the point of the spin shaft will get rid of any squeaks or squeals. DO NOT oil the roller wheel as it will slip on the drum. 2. Dryer drum seal. This is a felt gasket or seal that is glued to the rear ring of the drum. When they get old they become brittle and pieces start to break off leaving bare metal scraping against bare metal. They also can become folded and part of it will be seen poking through the back of the drum inside. This seal should ride evenly around the outside perimeter of the drum and should not be seen inside the drum. 3. Dryer drum support glides. Some dryer models have teflon plastic support glides mounting around the ring of the front of the tub, or will have teflon supports mounted under the front of the drum. In either case, if the plastic gets too worn down, the dryer will start to make a scraping noise. 4. Idler pulley. This is a little pulley that provides tension on the dryer drive belt. It is located near the drive motor and can start to make noise. Usually a little bit of lubrication at the point of the spin shaft will get rid of the problem. 5. Dryer drive motor. Sometimes when the drive motor gets a nice collection of dust build up around it, the motor will make noise as the impeller rubs against dust or any other debris caught. A stiff cleaning brush and a vacuum cleaner will help get rid of dust accumulation around the motor. Now, there is a possibility that the bearings in the motor could be going bad too. You would need to remove the drive belt and check to make sure the motor free spins with no power applied. Give the motor shaft a spin. It should glide free with no noise. 6. Dryer drive belt. When the belt gets old it will develop a "glaze" on it and start to slip around the drum. This can causing a squealing noise, especially under heavier loads. This is usually a prelude to the belt breaking. Start with the easy and simple options first. Try lubricating any drum rollers or pulley rollers. DO NOT get oil on the drive belt. Lubricate the rollers at the point of the spin shaft only. Inspect the front and rear of the drum. The seal will be in the rear. Make sure that it is intact and good condition, and make sure it has not folded inside the drum. Also, check for glide supports around the front of the drum and make sure there are not areas that are worn down. Another thing that COULD cause noise, but may not be associated to the problem you are having, are foreign objects getting lodged between the dryer drum and casing. Screws, paper clips, nails, etc., have been known to get caught in these areas and will make some awful noise. If you try everything and the unit still makes noise the drive motor bearings could be going bad. This is usually not likely and the motor can be very expensive to replace. Last of all, some heat on the top and rear of the dryer are normal. However, if it is excessive (you can't place your hand on it and hold it there), you probably need to give the inside casing a good cleaning. This could be a sign that your dryer ducting has become clogged and the unit is actually overheating trying to fight for air. Ask yourself, "Are my clothes taking a longer time to dry?" If the answer is "yes" then you need to clean the unit out and check the entire length of the ducting to ensure it is blowing air out of the vent. Remember also, the shorter and straighter the ducting run, the better. Any sharp bends or kinks (behind the dryer) will cause lint to back up. I hope you find this advice helpful. Good luck and let me know if I can help further.
Jul 01, 2007 | Frigidaire FDE336RE Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
226 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
