Question about Nokia N97 Cell Phone
Hi my new n97 wont charge or turn on - Nokia N97 Cell Phone
I bought a brand new nokia phone N97 but it does not charge. What must I do?
Posted on Feb 28, 2011
Nokia n97 charging solution
Hi If the USB Socket (usb board) found no damage the only thing is to apply jumper.So, you can contact nearest mobile repairing shop or follow this link N97 charging solution.Thanks for visiting fixya
Aug 20, 2012 | Nokia N97 Cell Phone
My nokia n97 is not charging its show not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 14, 2012 | Nokia N97 Cell Phone
Hi my nokia n97 mini is not charging properly and isnt turning on either. i have two chargers for it. the plug-in wall charger is about 2 months old and i have an in-car charger which is about the same...
Make sure your battery isn't fully drained. Make sure your battery has at least 3.1 V. Anything above that is good. You can check this by using a voltmeter/multimeter
If the battery is OK, make sure both of your chargers are working. Both of them can be bad. You know, there is a posiblity.
If the chargers are fine and the battery is fine, it's probably a hardware fault. Hand it over to a repair shop
Jun 19, 2017 | Nokia N97 mini Smartphone
CANNOT CHARGING MY NOKIA N97, THE INDICATOR LIGHT IS NOT BLINKING, ONLY DISPLAY NOKIA AND THEN OFF
Please check your battery, it might have already been damaged. My battery was already bloated, and hard to put the back cover when I encountered the same problem. You may also borrow a battery, from a friend just to verify it. Before checking the battery, I did some verification using a known good nokia charger from a friend, and still could not charge it.
P.S. I replaced my battery after using my N97 for more than 3 years.
Feb 05, 2011 | Nokia N97 Cell Phone
My Nokia N97 is charging but the light is blinking and not at a solid light. When i try opening it, i wont open. What can i do to fix it up?
Im not sure ... what you are describing is typically a battery issue. You may have to replace your battery to overcome this problem.
Thanks for using FixYa.com
Sep 29, 2010 | Nokia N97 Cell Phone
Hi, I am facing problem in getting my new Nokia N97 recharged. When i turned my Mobile Off the charging light on left side appears very bright and Mobile gets charged properly. but when i turn it on and...
this issue is generated from some types of software problems, you need to get back to Nokia dealer and they will solve you the problem in a seconds
Aug 25, 2010 | Nokia N97 Cell Phone
Hi,my nokia n95 wont hold charge i have a new battery and new software,do you know what the problem could be,also when it charges it doenst cut out when it is charging it just keeps charging,thank you
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Dear user,
Such issue may appear when Nokia charger adapter CA-146C is used with incompatible charger to charge Nokia N97. Currently compatible chargers for N97 with CA-146C are Nokia Travel Charger AC-4 and Nokia Compact Travel Charger AC-5.
Spangley, just plug it into your PC. If your battery needs charging, it will charge slowly simply while being connected to your computer. Nothing else to do!
Goodluck :)
Dec 11, 2009 | Nokia N95 Cellular Phone
Nokia N97  Cell Phone Logo
508 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
