Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
I recently purchased an Intex pool about 2 months ago. It came with a pump and at first we didnt have any problems with it. All of the sudden there is air in the hoses and it makes an awful noise. I have tried everything i can think of. We have cleaned the filter. We have tied the hoses up in different areas to try and help this problem. We took hoses off and made sure they were tight. What else can I do?
  • 2,841 Answers
Disconnect the pump from the power source. Turn both water valves on the side of the pool off. Now turn on the water valve on your right as you look at the pool. Now open the bleeder valve on the top of the filter cartridge. Leave it open until you can see or hear no more air escaping. This may take a couple of minutes. Now open the bleeder valve on the back side of the pump and do the same. Now open the water valve on the far left side of the pool. Plug the pump in and turn the pump on. If you still have air in the system repeat the process. You must do it in the order I described. Need an owner's manual go here; http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143
Posted on Jun 01, 2010
Purchased this mob before two months but on connected with pc shows ' USB DEVICE ODES NOT RECOGNIZED. pl. do some thing'
it may not be compatable or you need to get software installed for the item you are using..
Nov 19, 2013 | Intex Pool & Spa
I have a model 604 - one day the pool pump stopped working i dont know if its the pool filter or just the pump itself (the pool filter is dirty as havnt changed it over for nearly 5 weeks) if i buy a new...
No it won't. I stay in South Africa and bought the pool about 3 months ago. The impeller broke and there are NO aftermarket parts available. Buy a new pool!!! The only way of getting the same pump. I have checked on some other sites and a lot of the guys use a normal pool pump after they have experienced the same problem.
Mar 05, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I purchased an INtex 9 x 18 Rectangular Pool less than a month ago. Th "all in one system" works fine when you select the "FP" (Filter Pump) cycle. However when you switch to the "salt water system" cycle...
Service light is not fixable by the consumer
you will need to call intex
they will e-mail you a form fill it out and fax it back to them
you will have a new pump in a few days to your door
it must be under 2 years old and you must have a valid receipt
Aug 29, 2010 | Intex Automatic Salt Water System for ...
I have the 18 ft x 48" intex easy set infletable pool and it has been set up for almost 1 month. Until a couple days ago I had no problems. In the morning I noticed the water level was down more than a...
This should be easy ... a foot of water? I would suggest you are leaking out the bottom. do you have a mask and snorkel? Watch the bottom from a floating position ... you might find the hole ... there are underwater patch kits for this very purpose.
Aug 24, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
Intex salt water pump purchased 3mths ago water running threw it but cant get any display no boost no working light noithing?????? any suggestions
The manual says that it's fried. Sounds like something is wrong with the power supply unit. Call their 800 number and ask for a replacement. Hopefully you kept your receipt....
Jun 30, 2010 | Intex Automatic Salt Water System for ...
The green chlorinator light has not come on since we started the pool up a couple weeks ago. There is absolutely no buildup on the cell and no alarms are going off.
Are you waiting up to 10 minutes for the light to come on?Is the timer being set corectly? It is not immediate and could take up to that amount of time.
If this is not the case you can call intex and with a valid receipt they will send out a new unit up to 2 years after purchase
Jun 15, 2010 | Intex Automatic Salt Water System for ...
I have purchased 3 easy set pools in 3 years due
Hi, How long is the extension cord you are using? if it is longer than 20 or 30 feet, that could be causing an issue with the current to the pump, and cause it to burn out prematurely.
If you have a manual for the pump, check to see if there is a limitation on the length of cord or distance from the outlet that you can set up the pump.
May 03, 2010 | Intex 10' 30" Easy Set Pool Simple + Pump...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
269 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
