Question about Dell UltraSharp 2007WFP Monitor
When I try to start my Dell 2007WFP LCD monitor, it won't turn on! I've tried to change powercable! What do I do to fix this?
    Brigadier General:
  • 10,406 Answers
Take the LCD to any TV/video repair-store, and get a qualified technician to trouble-shoot it.
Posted on May 31, 2010
Testimonial: "Could be more detailed, like "intence heat, just buy a new one!", but okey!"
  • ikkenom Jun 10, 2010
    There are no "user-serviceable" parts inside an LCD monitor.
    So, if you've replaced the power-cable, with no improvement,
    there's nothing more that you can do, except to suspect that
    the ON/OFF switch is not working, and then to take the monitor
    to a qualified technician.
    When you do turn it on, do you hear anything,
    such as a quiet "buzzing" of the power-supply,
    or "crackling" of high-voltage arcing?
    Do any lamps light up?
    Do you smell anything burning?
Look at this link:
http://www.badcaps.net/forum/showthread.php?t=8603
I believe the Bad Power Supply cause this problem,
most likely need the new replacement of DELL 2007FPw CCFL Inverter
Posted on Aug 19, 2010
4 Suggested Answers
VOTIT
  • 2071 Answers
SOURCE: Ghosting on DELL 2007WFP
Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors.
Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
Posted on Jul 24, 2008
SOURCE: dell 19" monitor screen turns blank
i had same problem, fault was traced using a multimeter set to diode measurement, i found that one of the high power switch transistors in the inverter side of the power board was short circuit (there are four in the same area sticking up from the board, not surface mounted). normally they should measure 450 ish but when they read 0-010 its gone, pulled it out of circuit and remeasured it, gone, replaced and fixed.
Posted on Mar 10, 2009
romsky79
  • 822 Answers
SOURCE: Dell 1704 FPt lcd monitor power button blinking green, no screen.
the only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Posted on Aug 15, 2009
I have used a flatron W1934S for approximately a year and then it just stopped working. The screen is blank and the blue power button is flashing. I temporarily connected the computer to another flatron...
I'm sorry to hear that you have a problem with your monitor. There are a few things you can try. If these won't work, probably something fried from the inside that killed the monitor. First of all, try disconnecting the power cable from the monitor, if this is possible. If the powercable is hardwired (meaning you can't disconnect it from the monitor itself) to the monitor, unplug the cable from the wall. Reconnect and see if this works. This worked with a monitor i had that had this kind of problem. If it's still not working, and the powercable isn't hardwired into it, try a different cable. If this doesn't work, the LCD bulb might have gone bad, and needs a replacement. You can find usefull tutorials on the web how to do this. If you can, check everything inside. If something fried, it's dead, if nothing is wrong, the LCD bulb has gone bad and needs a replacement. I hope i helped you, if you can't do this yourself, please go to a computer repair centre and let them take a look at it, and i hope this problem gets fixed fast!
Jun 28, 2011 | Computers & Internet
The monitor is a Dell? UltaSharp 2007WFP 20.1 Inch Flat Panel Monitor. I Tried everything. different power cables, DVI cables, VGA cables, disconnecting everything and reconnecting. NOTHING WORKS. I even...
Not sure if this is your problem, but I have seen this with another Dell monitor on three separate occasions. The solution I found was to turn off at the wall power socket, unplug at the wall socket, plug back in, turn on at socket etc and everything was fine. Guess something hangs up somewhere.
Dec 08, 2010 | Dell Computers & Internet
Dell 2007wfpb monitor. No power present. Looked at capacitors but saw nothing unusual.
First check on the fuses in the panel, if bad replace with the same current rating, but if ptherwise Power supply board just die.It can be dead at anytimes.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 27, 2010 | Dell UltraSharp 2007WFP Monitor
Dell Inspiron 531 (desktop) won?t turn on/boot
You've either got a bad motherboard or a bad processor (I'd lean to the motherboard being bad). I would honestly take this into a computer repair shop and have them check both.
Oct 22, 2009 | Dell Computers & Internet
Will not turn on. i have tried different outlets different cords and different computer.. it will not turn on
There are no "user-serviceable" parts inside a LCD monitor.
So, all you can do is to take it to a qualified TV/video technician, for trouble-shooting. Or, just responsibly recycle it, and buy a new one. Some stores may give you a "trade-in" on the old one, because the LCD screen itself may be OK, i.e., the problem is in the "electronics".
Jun 30, 2009 | Dell UltraSharp 2007WFP Monitor
Then is the video card , I explained on other thread how to proceed to replace.
Let me know if you need more help.
Jul 24, 2008 | Dell UltraSharp 2007WFP Monitor
Dell 20 inch lcd monitor 2007WFP
Yes, If you have it sent in for repair they may be able to do it. Geek Squad would not be able to do it in the store. Although in most cases it is more costly then a new monitor. If it is still under warranty I would try and do it that way.
Good luck,
Lee
Jun 13, 2008 | Computers & Internet
Dell UltraSharp 2007WFP Monitor Logo
1,636 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
