Question about HP DeskJet 5150 InkJet Printer
There is a dark gray flexable flat plastic cable for lack of a better word that comments to the ink cartridges on the right hand side. It popped off. The tab at the end with a hole is in tact, and not torn. Where does it attach to? How do I reach the place where it attaches? Thank you very much.
    Brigadier General:
  • 10,406 Answers
This is the "belt" that pulls the print-heads across the page, as the page prints, line by line.
I recommend that you take the printer to a qualified technician, to see if it can be replaced. However, the cost for the technician's time could be LARGER than the cost for buying a new printer.
Posted on May 31, 2010
Samsung LCD TV diagnosis. Possible tcon board?
T-con board is causing all your problems. You are correct. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2015 | Samsung Televison & Video
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    I changed the ink cartridge but after that the lights indicating "ink" near the stop button lights us every time i turn the printer on. Some body help me.
    Check to make sure you have installed the cartridges the correct side up. The B side should be facing up with the bar code on the right hand side. The cartridges should be the medium gray and not medium blue.
    Jul 01, 2010 | Office Equipment & Supplies
    How to change ink cartridge? mfc240c
    The four ink cartridges on the Brother MFC-240C are located on the right side of the printer. Pull open the gray cover (there's a tab on the right side) and then you'll see a purple handle for each cartridge. Pull out the handle for the cartridge you want to replace, slide the cartridge out, then slide the new cartridge in (after removing it from the packaging and taking off the yellow plastic cover).
    Once you insert the cartridge so it snaps in place and close the cover, the machine should recognize the new cartridge.
    Apr 15, 2010 | Brother HL-2040 Laser Printer
    I have a lenmarx x5150 printer and have no manual with instructions.How do I use it and replace ink?
    • Press the "Power" button to turn on your Lexmark
    • Step 3 Lift the gray plastic cover on the left. Remove the empty black ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color ink cartridge.
    • Step 4 Remove the new black ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    • Step 6 Slide the black cartridge into the slot on the left side and push it down. Slide the color cartridge into the slot on the right side and push down.
    • Step 7 Push the gray plastic cover down over the cartridge until it clicks closed. Push the purple plastic cover down over the cartridge until it clicks closed.
    Nov 19, 2009 | Office Equipment & Supplies
    Where do you insert the ink cartridges on lexmark x4650
    These are the instructions for X2500 Printer
    1.Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
    2.Open the top portion of the printer to reveal the ink cartridges.
    3.Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
    4.Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
    5.Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
    6.Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
    7.Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
    8.Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
    Oct 25, 2009 | Lexmark X2500 All-In-One Printer
    I purchased a Epson sty lus cx6400 second hand
    Open the lid and look on the left hand side of the printer unit approx 4 inch's behind the on/off button, There is a usb connection.
    May 09, 2009 | Epson Stylus CX6400 All-In-One InkJet...
    Dell 920 Printer is giving annoying horizontal white lines
    We can try one more thing here...
    Cleaning the encoder strip...
    1. Turn the printer off.
    2. Take the power cable out from printer.
    3. Open the front cover .
    4. Using a dry, lint free cloth, pinch the encoder strip on the right-hand side of the cartridge carriage and pull your fingers across it toward the right-hand side of the printer.
    Note: The encoder strip is a narrow band of clear plastic and can be difficult to see without direct lighting running parallel to metallic rod.
    5. You can move the ink cartridges manually to a side so that you can clean the strip completely.
    6. Close the cover, connect the power and turn on the printer and try again,
    It should work....let me know if it does
    Nov 11, 2008 | Dell A920 InkJet Printer
    HP DeskJet 5150 InkJet Printer Logo
    Seeker5211
    Seeker5211
