Question about Craftsman 3/8" Corded Drill
On a model 315.101231 3/8 corded drill I need to remove the keyless chuck how do I do that?
  • 59 Answers
If you open the chuck as far as it will go and look inside you may see the head of a screw, especially if the drill is reversible. So undo the screw and then you should be able to unscrew the chuck. But I am not sure if it will be easy to unscrew. With a keyed chuck you use the key and a hammer to unscrew the chuck.
Posted on Jun 03, 2010
Require a 10mm and a 13mm Male-fitting Keyless Chucks
I suggest that you do not proceed, Keyless chucks can be problematic especially if dust /debris from material being drilled gets into the chuck. I have had to remove the Keyless chuck from my B&D drill and replace it with a keyed chuck- no problems since.
Apr 04, 2017 | Drills
How can I replace the keyless chuck on my Dewalt DWD215G?
Open the chuck wide open. In the center is a retaining screw, they usually have left hand threads. Remove the screw. Take an allen wrench1/4" to 3/8" in size and fasten the short side tightly in the chuck. The chucks are usually right hand thread, so take a small hammer and strike the allen wrench to turn the chuck to the left to loosen it. Once you have the chuck off, verify the thread size of the drill motor shaft, then go to McMaster-Carr and choose the one you need.
Apr 16, 2011 | Dewalt DWD215G 12Inch 10AMP Heavy Duty Mid...
How do I remove the Chuck from my Mikida 9.6 volt keyless drill
Dont know about a Makita, but my Craftsman drill , if you open the chuck all the way and look inside the hole where the bit goes, there;s a screw there that you can use to remove the chuck. amybe yours is the same way.
Nov 23, 2010 | Makita Keyless Drill Chuck Set, HP1501...
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Relace keyless chuck
It really depends on the model. Here is a general description of how to remove most regular keyed and keyless chucks from corded and cordless drills:
Some chucks have a Left Handed screw that secures them to the spindle so they do not come loose. You can look into the chuck with a flashlight and see if there is a chuck screw. (It may be a torx head, flat head, or philips head) You will need to remove this screw first before doing anything else. Sometimes there is loc-tite applied to the screw so it may be stubborn and sometimes you will strip the screw head. Remeber that the old saying lefty-loosey, righty-tighty does not apply here. Left is actually tightening a left hand thread, so you want to turn it right to loosen. I know, it will feel weird but thats the way to loosen it. You may have to apply some heat to the screw in order to get that loc-tite to break. A pencil torch works great. If you strip the head out you will have to use a drill press and drill the screw head off.
After removing the screw you can remove the chuck.
To remove the chuck, the easiest way is to use a hex socket bit and an impact wrench. Put the hex bit in the chuck, and depending on the condition of the jaws, tighten the jaws as much as possible to the hex bit. Put the impact in reverse and bump it until the chuck is loosened. If you do not have access to an impact wrench you will need to put a hex key with a long arm into the chuck and tighten it then place the drill on the edge of your bench and give it a good whack with a 3lb hammer. It may not come off immediately so you may have to reset and do this a couple of times. Not the most effective way to remove a chuck, especially if one of the jaws is missing, but that is what most manufacturers tell you to do. I myself cut the collar off with a die grinder and then use a pipe wrench on the body of the chuck applying constant pressure while heating the chuck body with a torch. Works every time. Heat is our friend on stubborn chucks. Good luck, any questions please post.
Oct 22, 2009 | Craftsman Drills
Cannot get keyless drill chuck off . this is Skil 6260 corded drill. It is stuck closed.l
Get two pairs of multigrips or a vice. If you have the drill facing away from you will need to turn the base of the chuck clockwise and the top anti clockwise. Put a cloth on chuck to stop it being scratched.
Aug 30, 2009 | Drills
Chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Jan 01, 2009 | Makita 6304LR 1/2" Chuck Electric Drills
Craftsman 3/8" Corded Drill Logo
282 people viewed this question
Top Craftsman Drills Experts
Tim Venetis
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
