Question about Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens
Focus ring jammed, lens having been dropped
Is it possible to repair this lens DIY?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Yes, it's possible. Do you have a lens collimator and other equipment needed to make sure the lens elements are aligned properly when you put it back together? If not, I strongly suggest you leave the job to a properly-trained professional technician.
Posted on Jun 01, 2010
Tokens focus ring jam
Unfortunately, I think this'll mean a trip to the repair shop - I certainly wouldn't advise a DIY attempt (speaking from bitter experience !)
Dec 28, 2015 | Tokina 11-16/2.8 At-X 116 Pro Dx Lens For...
100-400mm canon lens can't adjust focus ring on outside it is locked and will not budge
Assuming you are switched to MF manual focus and not AF then It's a recognised problem with that particular lens, in that some bearings under the focus ring become dislodged. It is not fixable by DIY means and will have to be returned to Canon or a repairer.
Jul 09, 2014 | Canon Cameras
Lens will not extend when turned on message on screen lens error
This error indicate that focusing ring got stuck or jammed due sand, dust or may be due to external shock caused by dropping the device.
  • Try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move once or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks and have a nice day
Jul 04, 2011 | Fuji Cameras
WHEN I OPEN MY CAMERA THERE IS A WORD E18.
Canon E18 error shows when the lens gets stuck while trying to extend.
  • This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device. try compressed air. With a fine tip blow off gun around lens barrel. It should remove all dust and sand. Turn the camera on this will solve the problem.
Jul 04, 2011 | Canon PowerShot A470 Digital Camera
When power ON the screen displays"Lens Error!" & lens does not open.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
I own a casio exilim ex-z850. it has been showing a lens error, every time i try to take switch it on. the memory card is fine, i view the pictures. but the lens wont open up or anything. please reply...
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Sep 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
Carl zeiss Pancolar lens for Exacta. Focusing ring will not turn - i think the camera has been dropped - can I repair this?
it is not likely that you can repair a camera lens. if the lens was less than 400 dollar or Euro then it is problaby cheaper to buy a new one. any repair shold be carried out by a lab, any dust or fingerprints inside the lens surfaces will render it useless also a lot of lense are glued together so that they do not shake apart as this will effect focus so it may not be possible to get into this anyway.
Nov 17, 2009 | Cars & Trucks
Fuji finepix f50 camera was dropped with lense out, and now wont return. it also says focus error on screen. I have the same problem and Fuji want £88.00 to repair it - you can buy a new camera for...
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
Feb 13, 2009 | Fuji Finepix F50FD Digital Camera
NEC VT37
you auto focus or you can manually rotate the lens for focus
Feb 22, 2008 | NEC VT37 Multimedia Projector
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX (silver) Lens Logo
255 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
