Question about Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive
Storage disc stop working
Computer asking to format the disc but i will losse my files how can im save my files if the storage maxtor stop working
    Brigadier General:
  • 10,406 Answers
It could be a situation where only the "table-of-contents", which describes all the files on the disk, has become scrambled. So, look online for "file recovery" utilities -- programs that will read through all the blocks of data on the disk, and try to "stitch" together all the files, without using the "damaged" file-directory.
Posted on May 31, 2010
Hi. I configured my Maxtor Shared Storage II with my home PC. Now the PC is dead. I tried to connect the other my PC (with Windows 7 as operating system) to Maxtor Shared Storage II, but the PC cannot see...
try and assign the drive a drive letter by right clicking on my computer and choose manage.
go to disk management
look for the maxtor hard drive.
if you see it listed there below you should be able to right click on it and assign a drive letter.
if you dont see it then it doesn't detect the hard drive. please check your hard drive connections and try again.
Mar 06, 2011 | Maxtor Shared Storage II (S01R320) Hard...
For no reason whatsoever, my Maxtor external drive stopped appearing in My Computer. I've tried on three different computers, but each one only gets me the following message: "Error 10, The device...
yep --the disc is spinning , the lights are on BUT the pickup arm that reads the disc is not working
Time to consider a new unit preferably a solid state unit that has no moving parts to wear out
Jul 21, 2017 | Maxtor Personal Storage 3200 (U01E200) 200...
I am afraid of losing my pictures on it. I have always been able to get into them and now it is asking me to format. Won't that lose my files Maxtor Personal Storage 3100 7200 RPM 80GB USB 2.0 When ever...
Try this:
1. Plug Maxtor External Hard Drive into your computer
2. Go To Computer
3. Right click on the Drive
4. Click Properties
5. Go To Tools
6. Run an Error Check.
That should help, if not let me know so we can proceed with something else
Aug 11, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Files saved on the maxtor hard drive become read only. I cannot make changes to the files and save it.
The cause of read only files are the files open by other network. To fix this problem copy your files and save it again to your computer. Or you may open the files and save it again in different file name.
Mar 26, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor 3200
Try connecting the Maxtor to another computer and if it functions normally, then backup your data. Then try formating the Maxtor on your computer.
Sep 08, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My 200GB Maxtor has somehow changed from the storage drive to a local drive. Now Windows can't open this drive for viewing and keeps asking me to format the drive. It was working fine till last weekend as...
Suggestion 1:
Try exploring the drive from Disk Management:
1. Click Start
2. Right-click My Computer
3. Select Manage
4. Select Disk Management
5. Right-click the inaccessible drive and select Explore
Suggestion 2:
If that doesn't work, try changing the drive letter:
1. Click Start
3. Select Manage
5. Right-click on the inaccessible drive and select Change Drive Letter and Paths
6. Click the Change button
7. Select a different letter from the available drop down menu
8. Click OK>OK
Perform the same steps from suggestion 1.
If the drive is still inaccessible, it's likely that somehow the NTFS master file table (MFT) has become corrupt which is causing Windows to believe it needs to be formatted. Unfortunately, it's not an easy to task to return the file system back to its correct state.
It may be possible to use a file recovery application such as Stellar Phoenix Photo Recovery to recover the lost data. It's relatively cheap for one of those programs and may help you save a good chunk of your data. Here is the link to Stellar Phoenix Photo Recovery:
http://www.stellarinfo.com/
I used it once when I forgot to format my memory card in my camera. I was able to save 230/250 photos.
Hope this helps. Good luck!
Aug 09, 2009 | Maxtor (6Y200L0) 200 GB Hard Drive
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Does maxtor 3100 storage automatically add file to itself?
Yes, it is wise to do a house cleaning on your Maxtor. Whether you delete everything or not is up to you. However, do not do this by formatting the hard drive.
If you find you need a file later you deleted from the drive, a free program called 'FileScavenger' can recover it for you. If you format the hard drive the ability to recover a file becomes highly unlikely.
We techs have expensive software to recover files should you need to get it retrieved, but the interface is designed for techs and not the average user.
Regards,
Worldvet
Jun 08, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor Personal Storage 3100 (M01E100) 100 GB Hard Drive Logo
207 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
