Question about Craftsman Garden
After priming lawnmower starts it runs for a few seconds and then stops
  • dbabina Jun 05, 2010
    yese i get a continous flow of gas but now the throttle idles roughly
  • 6,982 Answers
You need to make sure that if it has a filter between the tank and carb that fuel is getting through it. Also make sure there isn't any junk inside the tank.
If the carb has a fuel bowl, usually the bottom nut that holds it on has two tiny orfices near the bottom that allow fuel to flow through If they become blocked they are nearly impossible to see but they can be cleared using a straight pin and some carb cleaner. The nut is not only a nut but also serves as a fuel metering device. Depending on how the mower was stored, the carb can also internally corrode. sometimes it can be cleaned out, sometimes they need to be replaced (last resort though).
In running with a prime, it's telling you it has a fuel delivery problem.
Posted on May 31, 2010
3 Suggested Answers
01fordeb
  • 1033 Answers
SOURCE: I can start my 4.75 HP Briggs & Stratton
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Posted on Sep 05, 2010
daneinwv
  • 124 Answers
SOURCE: mower starts after prime,runs for a few seconds
My name is Dane and I am going to try to help you solve your problem. I believe that you have clogged jets/passages inside of your carburetor. This can happen when an engine gets little use, allowing the fuel in the system to get old and begin breaking down. If fuel is left in a carburetor for more than a year, it can eventually turn into a jelly like consistency, and clog the fuel system.
The other way to block these passages is to allow dirt or other debris to enter the fuel tank. This will be picked up through the fuel line, also clogging the system. The easiest way to determine if you have a clogged fuel system is to remove the air cleaner/filter, and spray a little starting fluid directly into the carburetor opening, and crank the engine. Do not use a large amount of starting fluid. If it starts for a couple of seconds and then quits, you've found your problem. A clogged carburetor. If not, you have another problem. Using too much can harm your engine.
You will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the carburetor from the engine. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air before you assemble and reinstall it.I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
Posted on Dec 06, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
My craftsman gasoline lawnmower will start when primed run less than a minute then cut out . how do I determine the problem...then fix it
Have you checked the fuel supply first. Its possible your jet valve may be plugged or dirt in the fuel bowl. One quick way of checking this is take the spark plug out and put a little shot of gas in the spark plug hole then reinstall the spark plug and put wire back in place and try to start engine. If it start and revs up for a few seconds till the gas is burnt up then stalls it is pretty certain its a dirty fuel jet or dirt in the fuel bowl. This quite often a real cheap fix .
Jul 20, 2015 | Craftsman Garden
Why wontsmart carb engine start if primed runs for few seconds
dirt or water in the carby jets
priming it just puts a squirt of fuel in the manifold and that is the initial start run
Jun 19, 2015 | Garden
Lawnmower starts when primed only then stops
All mowers have a low oil cutoff. Fill oil. 30w.
May 29, 2013 | Garden
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 | Garden
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Sep 05, 2010 | Craftsman Garden
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Garden Logo
48 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
