Question about Samsung HLS4666WX 46" HDTV
My Samsung HLS4666WX TV has started shutting itself off. After turning itself off, the three indicator lights on the front of the TV (Standby, Timer, Lamp) flash in unison. After leaving. I can turn it back on, but then it shuts itself off again after about 10~15 mins. Any insights?
  • Samsung Master
  • 8,457 Answers
The lamp in the tv been in use about 1 1/2 or 2 years,the tv on about 4 or 5 hours a day?The lamp life span is over.Replaced the lamp.
Posted on May 31, 2010
Tip
Error code by led indicator samsung SP67L6HX1X
<img src="mas_baz.jpg" /><br />There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.<br /> <ul> <li>LAMP blinking : The picture will automatically appear in about 15 seconds.</li> <li>TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.</li> <li>LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.</li> <li>STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.</li> <li>All LED blinking : Lamp may be defective.<br /></li></ul>It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.<br /><br /><br />
on Mar 29, 2011 | Samsung HL-R6167W 61" HDTV
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
Sep 30, 2010 | Samsung HL-P5063W 50" Rear Projection HDTV
No picture or sound
Hi, your color wheel needs to be replaced, the bearings fail causing the grinding noise, the new ones use "air bearings" so they are supposed to last much longer, video-tek
Mar 26, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
TV turns on at night.
check your TV's timer setting. typically you'll notice something different about the standby light - for example, it might be a different color, or might be blinking, etc to indicate that the timer feature is activated.
Mar 19, 2009 | Hitachi Televison & Video
My DLP TV shut itself off & won't turn on, help!
The 3 lights on the tv are there to help you diagnose the problem. There should be Timer, Lamp, and Temp. If all 3 are blinking, the LED may be defective. If standby and temp are blinking, it's a problem w/the cooling fan.
Let me know if that helps.
Dec 15, 2008 | Microsoft Xbox 360 Console
Assistant
is this electricity pocket plugged up to a timer ? or take the tv back to the shop... lost the receit just look for the same tv on computer
Feb 20, 2008 | Toshiba 28N33 28" TV
Samsung HLS4666WX 46" HDTV Logo
668 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
