Question about Shuttle MV42N (SHUTMV42N) Motherboard
Connect front panel (reset, power, leds), I need manual, please
    Champion:
  • 253 Answers
Power switch
You maybe able to download a motherboard manual from this WEB site and identify the connectors for the front panel.
http://devxstudis.org/int/intel+d865gkd+motherboard+manual.html
Jan 03, 2013 | IBM Computers & Internet
Mercury Motherboard PI845GLM-L manual needed for wire connections... please help me
If my information is correct;
Orient the motherboard so that we are both looking at it in the same direction,
Processor to the top, Ram Memory slots to the right, white PCI slots to the bottom.
The front plastic panel of your computer that has the Power On button, Harddrive activity LED light, and Power On LED light, is the Front Panel.
The area of pins on the motherboard, that the wires from the Front Panel go to, is the Front Panel header.
The Front Panel header is all the way down on the right corner. Panel 1.
The Front Panel header, or Panel 1, is a rectangular block that is positioned lengthwise, across the bottom of the motherboard.
There are 4 pins across the Top, and 5 pins across the Bottom.
The pins are numbered.
They are numbered Even across the Top row.
Pins 2, 4, 6, and 8. (There is NO Pin 10. Just a blank spot)
They are numbered Odd across the Bottom row.
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED light. (HDD LED)
Pin 1 is for the Positive wire. ( + )
{ Pin 2 is for the Negative wire. ( - ) }
If the LED light is dim when operating, turn the wires around.
B) Pins 5 and 7 are for a Reset switch, (Reset button), IF a Reset switch is used.
Pin 5 is for the Negative wire
C) Pin 9 is RVSD_DNU
Reserved Do Not Use.
D) Pins 2 and 4 are for the Power On LED light.
Pin 2 is for the Positive ( + ) wire.
If the LED light is dim turn the wires around.
E) Pins 6 and 8 are for the Power On switch.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 16, 2011 | Mercury P4VM800M7 Motherboard
Installed mother to new tower case and pwr sw | hd led | reset | power led connecting to my board is the Intel dq67sw 155 matx motherboard need accurate dir to connect these please help
info found at http://downloadmirror.intel.com/19707/eng/DQ67SW_ProductGuide01_English.pdf
Front Panel Header Pin info for DQ67SW. They should be color coded too. 1 Hard disk LED + orange
2 Power LED+ green
3 Hard disk LED - orange
4 Power LED- green 5 Reset Switch - blue
6 Power switch + red
7 Reset switch + blue 8 Power switch - red
9 Power Out (do not use)
10 No pin
NOTE When connecting individual wires from your chassis front panel to the front panel header, be sure to observe the connection polarity. Positive wires are usually solid color and negative wires are usually white or striped.
There is also an alternative pin header if you have a power wire that uses a 3 pin connector instead of a 2 pin connector. It is the 3 pins just past pin 9, and it should be missing the pin in the middle of the 3 pin block. The pin closest to pin 9 is the power led + and the furthest from pin 9 is the power led -.
if you need clarification, check out page 50 of the manual posted above at intel.com
Aug 23, 2011 | Computers & Internet
How to connect the front panel sould device?
Do you mean speaker or front panel audio? The front panel audio connector is located at the rear of the board, behind the PCI connectors - the speaker connections are in the panel connector block (2x10 pin header) located at the front left of the board.
With the board in it's normal position, the speaker pins are on the right hand side of that block, on the pin nearest the front and the one 3 positions behind that
<back of board>
| HD LED + | | Power LED +
| HD LED - | |
| | | Power LED -
| Power SW | |
| Power SW | | Speaker
| Reset SW | |
| Reset SW | | Speaker
Front of board
Jul 03, 2009 | ASUS K8V-MX Motherboard
Can't Fix FRONT PANEL HEADER on my Motherboard
Here is a link to your motherboard manual:
D845PEBT2 Manual
Go to Page 33 for the Front Panel connections...with pictures. :-)
Thanks for using Fixya.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Simple pinout help
Front Panel Header pin assignments as follows:
Pins 2 + 4 = Power Led
Pins 6 + 8 = Power Switch
Pins 12 + 14 = LAN Activity Led
Pins 1 + 3 = HDD Led
Pins 5 + 7 = Reset Switch
Pin 9 = +5v
Pins 11 + 13 = ODD Led
Pin formation is as below with no pin in position 10.
2 4 6 8 10 12 14
1 3 5 7 9 11 13
You will probably need to extend the Front Panel connector cable to reach the header pins on a replacement motherboard - I did this with 2 x N76HL 10 pin extension cables (male to female) from Maplin.
Mar 26, 2009 | Computers & Internet
Front panel connectors
Pin Signal In/Out Description Pin Signal In/Out Description 1 HD_PWR Out Hard disk LED pull-up (330 ohm) to +5 V 2 HDR_BLNK_GRN Out Front panel green LED 3 HAD# Out Hard disk active LED 4 HDR_BLNK_YEL Out Front panel yellow LED 5 Gound Ground 6 FPBUT_IN In Power switch 7 FP_RESET# In Reset switch 8 Ground Ground 9 +5 V Out Reserved 10 N/C 11 Reserved In Reserved 12 Ground Ground 13 Ground Ground 14 (pin removed) Not connected 15 Reserved Out Reserved 16 +5 V Out Power
Hope this helps, , if so please rate accordingly.
Thanks,
David
Mar 12, 2009 | Intel Motherboard
Pin alignment on motherboard for led switches
Connecting the Front Panel Header
Table 6. Front Panel Header (J9H3)
Pin
Signal
In/Out
Description
Pin
Signal
In/Out
Description
Hard Drive Activity LED
Power LED
HD_PWR
Out
Hard disk LED pull-up (330 ω) to +5 V
HDR_BLNK_GRN
Out
HDA#
Out
HDR_BLNK_YEL
Out
Reset Switch
On/Off Switch
5
Ground
Ground
6
SWITCH_ON#
In
Power switch
7
FP_RESET#
In
Reset switch
8
Ground
Ground
9
+5 V
Out
Power
10
N/C
Not connected
Apr 01, 2008 | Compaq (283983-001) Motherboard
Shuttle MV42N (SHUTMV42N) Motherboard Logo
422 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
