Question about GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS)
GE monogram side by side built in refrigerator: fan behin Climate control drawer makes noise when it starts
This noise is made everytime fan comes up. How can I stop it ?
  • 2 more comments
  • sudeshp Apr 08, 2008
    I tried to change the setting on climate control drawer and made fan to start. I heard the noise every time it started and yes it felt like something was touching the fan. I will check out the assembly as you mentioned.
    thanks a lot,
    Sudesh
  • jlulich Apr 25, 2008
    I have the same problem with the fan in the top of the unit behind the compressor. When it turns on, it sounds as if something is touching it which causes a knocking sound. But by looking at it nothing is hitting the fan. Do I need to replace the fan? If so, how?
  • sudeshp May 16, 2008
    I called GE for same issue of noise from compressor compartment. It was nothing but a pipe was touching the compressor. This is drain pine behind compressor coming from ice dispenser. just reach incise and try to move it. It was a child's play.
    How can I take out Climate control drawer when my door only open 90 degree and I can not just pull out this drawer ? I thought about removing the door but do not know how.
    please advise. I like advise from Fixya.
    Novelist:
  • 184 Answers
IS THE NOISE SOMETHING HITTING THE FAN BLADE?
CHECK THE FAN ASSEMBLY BY REMOVING THE BACK PANEL IN THE FREEZER COMPARTMENT.
NORMAL NOISES IN THE UNIT ARE A GURGLING NOISE OR THE SOUND OF RUNNING WATER OR HISSING. THIS IS DUE TO THE FREON BEING PUSHED THROUGH THE SYSTEM AS THE COMPRESSOR RUNS. POPPING OR SNAPPING CAN OCCUR WHEN THE COILS IN THE FREEZER MOVE DUE TO A CHANGE OF TEMPERATURE.
Posted on Apr 08, 2008
My GE climate control drawer always has water in the pan . I wipe it out and when I return there is always water on the bottom.
Which model do you have? Its easier to tell you when I can get the information of the unit. I can guess, obstructed drain to the evaporator in the fresh food section, or a leaking water tank, but not sure as all units are not built the same. Thanks
Apr 11, 2016 | GE Monogram Side by Side Refrigerator
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Ge monogram zfsb23d howls
Usually you will get a sort of whinning/screeching noise from the fans inside the fridge/frezzer when they are not working properly but you can also get that howling noise from the fan which cools the compressor for the fridge/frezzer which is usually found underneath the Unit. All you have to do is find exactly where the noise is coming from and remember unless you have a dog that likes to lock itself in the fridge for a joke then most noises that come from fridge/frezzers are only made from the moving mechanical parts and sometimes leaking refridgerants but not often.
Apr 03, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
GE ZIS420NX Refrigerator temp control not effective, food is freezing
you have a few things that could be wrong, a bad thermistor, a bad air defuser, or a bad main board. changing the thermistor could fix it but if not, i would call a pro that order the right part. lots of varibles.
Apr 08, 2012 | General Electric GE ZIS420NX (25.4 cu....
Ge monogram zisw42emd, evap fan not coming on, Units been down a week, compressor seized,installed start kit. Compressor running 2.5 amps pressures 25/105 Replaced coil thermostats, evap fan not running.
that back pressures sound high to me and the hi side sound low may have a bad compressor not pumping right should run around 0 to 5 low 125 to 150 hi hope that helps
Oct 06, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
My Ge Monogram Refrigerator required maintenance cleaning on the condenser, typical with this type of built-in system. blew out the dust and cleaned it. the freezer is working fine but the refrigerator...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 18, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
My GE 48 inch built in fridge began making a strange noise.
fan motor problem ge has the solucion replacement fan motor around $350 plus mine still makes the noise
Jun 19, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
1,347 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Stan Ford
