Kenmore 800 series model: 11029832800 will not rinse or spin. It fills with water and then starts making a humming noise and will not do anything.
  • Washing Mach... Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineKenmore 800 series model:  11029832800 will not - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 31, 2010
My kenmore washing machine series 80 model stuck in soak cycle and will not pass to rinse cycle
This is usualy caused by the cold water not entering the machine. If you hear a humming noise it means the fill valve is operating but no water is present. Has some one turned the cold water off? Failing that the fill valve may be faulty and need replacing.
Oct 03, 2014 | Kenmore Washing Machines
Our Kenmore Top Load Washer series 800 is not working properly. When you set the Control Cycle knob to start a normal load it agitates instead of filling up with water rinses instead of stopping the load...
We bought our Series 800 Washer (and dryer) in 08/2009. My wife has never been happy with them. It is off warranty now 10/5/2010. We have always had Kenmore... but she hates this set.
We are having the exact same problem with this washer. The current problem is on the regular cycle when it gets to the spin segment it does spin and all the water is removed HOWEVER just before it shut off it fills with rinse water.
I'll bet any money they are made in China. Looking for a solution on the web. Sears is no help.
Jul 03, 2010 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Rinse cycle doesnt work
the humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
May 02, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
