Question about Home
Hot water drips. how to repair - Home
  • 2,100 Answers
The cartridge in the faucet is leaking, Turn off the water to the house, either at the water heater or the main line in, take the faucet handle off, and then the cartridge should be held on there by a big skinny bolt or ring, take it off, pull the cartridge out, and look inside the faucet for springs and O-rings, take the parts to the hardware store and match them up to a repair kit. Put it back together, you should be all set. Most faucets are built that way, single stem are the same, anti scald devices are tricky, do not let the rings fall out and make sure it goes back the same way if it is an anti scald unit. Older faucets are a little different, no cartridge, but still has rubber parts in there that are worn out. Hope this helps.
Posted on May 31, 2010
  • 8 more comments
  • cdjm May 31, 2010
    don't know how to take the faucet handle off! moen 4570
  • Ned  White
    Ned White May 31, 2010
    I couldn't find a 4570 in the tub fixtures, only the sink fixtures, is it a tub or sink? It doesn't matter, they have to come off either way, A tub faucet has a tiny hole in the bottom for an allen wrench, it is about 3/32", that will get the handle off. The sinks, usually have a plastic cap on the top that pops off and a screw inside. If not, look for the allen screw hole again. Depends on how fancy they are. Then get back to me and let me know where you are at and I'll try to get the rest of it for you.
  • cdjm May 31, 2010
    sink. No allen screw. I don't think it has a plastic cap either. Hot and cold separate. Installed 3 or 4 years ago.
  • Ned  White
    http://www.moen.com/shared/pdf/t4570pt.p...
    Check out this web site, your faucet should be close, you have to take the handle off first, then unscrew the barrel, it will expose the cartridge, check it out. let me know.
  • cdjm May 31, 2010
    taking handle off doesn't help. I may try taking apart from the bottom up. No time for that today.
  • Ned  White
    You will never get to it from under neath, taking the handle off just gets it out of the way, that barrel shaped bottom should turn off of there, while the cartridge doesn't move. Just the part that hooks to the handle moves so the water comes out. Did you get a look at the diagram? If you have to grab it with a pair of water pump,(channel lock) pliers, put a piece of rubber around it so you don't bug it up. It should be right hand thread. Normal. Check it out.
  • cdjm Jun 01, 2010
    Thank you. Got the barrel off. Now what? How do you get the cartridge out? Doesn't appear to be any screw in there.
  • Ned  White
    Ned White Jun 01, 2010
    If no lock ring or lock nut, just pull it straight up, turn the water off first. You might not need the whole cartridge, maybe just washers, but check it out.
  • cdjm Jun 01, 2010
    Pulled straight up with pliers. No give.
  • Ned  White
    Ned White Jun 02, 2010
    I was wrong, it doesn't come straight out, it has a tool for removing, So it must be threaded in the bottom, Can you turn it at all? Check out the diagram again, a see what it looks like.
    It might come off with your hand. Check it out. (I wish they would make them all the same)
Why is the hot water pipe dripping after tighening up.
First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
Oct 28, 2014 | Washing Machines
Bosch aq 125 bng
sounds like pressure relief valve is stuck closed free of or replace
Sep 24, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
Not hot water or heating
Good luck with the repair.
We always stand ready to support success.
Also post the brand and model number and type of product so expert can identify if you have electric or natural gas or propane energy, and identify if there is basic information online about your product.
Aug 24, 2012 | Water Heaters
We have a 15 year old Rheem "SK 1261" which recently has developed a steady and constant hot water drip from the hot water over flow. Initially it was a slow and inconsisent drip but now it...
If you are paying for your water, I litre per hour is going to cost you. If the unit is 15 years old, I would seroiusly comsider replacing it buy, if it's just a bad valve, you could try to replace it. If it is cracked at the threads, it's time to replace it for sure.
Dave
Jun 24, 2011 | Rheem Water Heaters
Our machine keeps dripping water once load is finished. We have turned off water and checked hoses as well as the water inlet valve. Everything looks fine. It is only when the hot water is on, I shut...
I would replace the inlet valves. Even though the issue is only a drip now, the failing hot water inlet will drip enough water to overflow and flood your floor if left unattended. The failure code you see is because the washer senses the water connections. It is telling you that there's no hot water available. Replace the valve- soon.
Good luck.
Jan 18, 2011 | KitchenAid KHWS02R Front Load Washer
Hot water leaks into the washer when it is not running
This is usually caused by a water inlet valve leaking by. The following link explains how to diagnose the problem yourself and repair:
http://www.fixya.com/support/r3753262-front_load_washer_fills_when_not_in_use
I've included parts sources (if required) and instructions on how to replace each component. These are very simple and inexpensive repairs that you can easily accomplish yourself.
If the model number is correct, the part number for a replacement valve is 8181694. The average cost is about $35.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cold water drips in instead of fills. Hot water
Inlet screen in the hot water hose is clogged (check at both ends) or the solenoid valve has failed.
Oct 30, 2009 | Kenmore 22422 Top Load Washer
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Maytag Insignia hot water dripping only (5 yrs old)
sounds like the diaphram in the water inlet valve is going on the hot water side. you need to replace the whole valve. turn off water and remove hoses. remove the housing that holds the valve and remove the valve. replace and reassemble.
Apr 07, 2008 | Washing Machines
Home Logo
35 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
