Question about Toro Lawn Boy Self Propelled CARB Walk Power Mower
Hello: I have a lawn boy self-propelled model 10682. It was working fine and I went thru some tall grass and the self-propelled stop working. I can not move the mower to the rear as the rear wheels are locked up? What happened??
  • 246 Answers
SOURCE: Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Posted on Apr 21, 2009
mhamlin63
  • 138 Answers
SOURCE: Self propelled lawn mower inside of drive wheel gears stripped.
Check the drive shaft bearing closest to that wheel.
Posted on Jun 29, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
  • 6468 Answers
SOURCE: front wheels do not move on self propelled lawn mower
check the cable at the front gear box
Posted on Mar 25, 2012
  • 6468 Answers
SOURCE: toro self propelled 22 inch recycler lawn mower not picking up grass
is there to much old grass built up under the mower?did you damages the blades
Posted on Apr 08, 2012
Why won't my 22 in. Kohler Low Wheel Variable Speed Self-Propelled Gas Lawn Mower self propel anymore?
i would guess that the belt is'nt tight enough when engaged. when you press the drive bar on the handle it should make the belt really tight if not it will need replaced. sometimes the gears in the wheels will mess up. there are videos on you tube that describe that and also the belt.
Apr 22, 2017 | Garden
How does the govener and carb linkage work on a Troy-Bilt 2005 800 Series (839) self propelled mower
Have you changed springs? Likely the correct components are there unless you have changed it. Does it run properly and at correct rpm when not in tall grass? Check for proper throttle adjustment first. also check for obstructions (packed grass for instance) under the deck that could be impeding the blade. Lastly, if you have the discharge blocked with a mulch plug, remove the plug. let the tall grass discharge. then run over it again and mulch it.
May 29, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Lawnboy 10665 won't self-propel and impossible to push
If you have the smell of rubber burning the belt isn't gripping. Make sure that there isn't anything stopping the wheels turning like old grass or even a piece of twig. If their clear try adjusting the tension on the drive pully.
Jun 28, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
Troy Bilt XP self propelled mower
Normally an indication of poor air flow. Replace air filter. Clean outside of carb with carb cleaned to ensure choke is free to operate. Go real slow in tall grass, some mowers don't have the torque to do tall grass, only use 1/2 of the deck width and have side discharge open.
May 10, 2013 | Troy Bilt 5.5hp Self Propelled Mower
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Grass collector not filling
HMM .. if the grass is not going into the collector, I would look under the deck and see if there is something blocking the chute to the bag.
Please vote !!
May 12, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Can't get my lawn boy started
check for a faulty wire to the engine kill switch it may be contacting the ground
Jun 22, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
My daughter called said she hit a stick with her new lawn boy mow
Check and see if the belt for the drive wheels is still on the pulleys.
May 20, 2009 | Tecumseh Garden
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Toro Lawn Boy Self Propelled CARB Walk Power Mower Logo
361 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
