Question about GE Spectra JBP78 Electric Kitchen Range
Auto clean on electric range
I auto cleaned my oven over a week ago. The auto clean light will come on blinking when I am trying to set oven. What can I do to stop this from happening?
  • rinmud Oct 14, 2008
    same thing i hope its not the control panel $111.00 or the thing gets a recyling trip
    New Friend:
  • 4 Answers
Try replacing the "logic switch" attached to the oven locking mechanism. I had the same problem and it worked for me.
Posted on Jan 23, 2010
SOURCE:
I have a Maytag electric double oven range MER6775. I need the instructions to run the self cleaning feature for the ovens.
FIRST REMOVE THE RACKS.PUSH CLEAN THEN AUTO SET T. PUSHING AUTO SET EACH TIME MOVES IT TO LIGHT MED HEAVY.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
JBP78 won't heat, breaker ok, stopped after auto clean
I need the Model # off the machine to help you.
Most comon problem with Electric range if The TOC or hi limit fuse after a clean cycle. This is usualy located in the rear of the machine behind the back pannel.
As always disconect the power to the machine befor trying to fix.
Jan 11, 2010 | GE Spectra JBP78 Electric Kitchen Range
I cannot get the auto self clean cycle to end
It sounds like your oven control module is bad. It conrols all bake, broil, including self clean.
Mar 25, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Lower oven door on range won't unlock after clean/cool cycle
try unpluging the stovr let set plug back in might reset itself if not u can remove the back to get to the lock then check to see if that good or bad u might need that locklatch or possibly a erc
Mar 17, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Blinking auto self clean light
There is probably a switch attached to the oven locking mechanism that need to be replaced. I had a similar problem on my GE electric oven and it worked for me.
Nov 16, 2008 | Kitchen Ranges
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool electric wall oven rbs305 oven is on, control panel shows on, 350, etc, but elements don't heat. Same for broiler element. Auto clean was run last week and the oven hasn't been used...
you have a thermal fuse open it is called a "T.O.D" it is located on the back of the unit or up in the top. the self clean very often pops these especially on the whirlpool units made 4-5 years ago very cheap part like $20 you can find it with the wiring diagram easy fix good luck
Apr 22, 2008 | Kitchen Ranges
Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
Dec 28, 2007 | Maytag MER6772 Gemini Electric Kitchen...
GE Spectra JBP78 Electric Kitchen Range Logo
261 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Kitchen Range Expert? Answer questions, earn points and help others
