Question about Refrigerators
The freezer (top) works fine but water leaking in the fridge
The freezer (top) works fine but there is water leaking into the fridge and water dripping down the back of the fridge and pooling at the bottom. I've tried to change the temperate settings but that doesn't make a difference.
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerThe freezer (top) works fine but water leaking in  - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 31, 2010
Water leaks inside food compartment
Your fan has stopped working. You need to either replace it or see if your defrost timer is working.
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Frigidaire plht189sska top freezer fridge problem. Freezer is cold, fridge is warm. About a month ago, had the problem of frost build up in freezer, water pooling under veggie bins, warm fridge. ...
If the defrost heating element, defrost timer or evaporater fan weren't working, you'd develop a block of ice on the evaporator. Is the compressor running? If it is, it might have bad valves from the frost buildup scenario. Liquid refrigerant could have gotten to the suction valves. The sealed system should have a five year warranty. Might be time to call a pro
Sep 15, 2009 | Frigidaire PLHT189CSB Stainless Steel Top...
Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
216 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
