Question about Whirlpool LEQ9858P Electric Dryer
Dryer to hot
Dyrer kicked breaker so after opening panel discovered broke wire going to element.repaired and when turned back on the element got red hot and the top and sides were way to hot.help!!
    Genius:
  • 1,073 Answers
The element is grounded to the element housing need new element and thermastat kit
Posted on Apr 10, 2008
Dryer not getting hot
First ck and make sure you have 220 volts to the dryer. It will run on 110v if one side of the breaker is bad. The other culprits are a limit switch heating element or thermal fuse. If you have 220 volts and the dryer runs just does not heat first turn off the power to the dryer and unplug the dryer from the outlet. Pull the dryer out and remove the lower back panel it is held on by several 5/16 hex screws. (not the back plate on the switch panel) Remove the back and your heater is on the lower right hand side and is inside an metal shell. The thermal limit is also on the metal shell and will have several wires running to it. And if you trace the wires from the element and this thermal limit it will go to the thermal fuse it is on the lower back slightly to the right of the dryer and has two wires run to it and is about the size of a dime or smaller. Unplug the two wires from the termal fuse and hook them together with a papper clip or just tape them together make sure it doesn't touch metal. (this will short it out) and then plug up the dryer and try it to see if it heats you do not need to hook up the vent. (make sure not to touch the back of the dryer and especially any exsposed wires. If it heats up your thermal fuse is bad replace it. If it does not you should check your heating element first unplug the dryer and reattach the wires to the thermal fuse. Then the heating element metal shell should be removed. First unplug the wires to the heating element and thermal limit switch and mark them so you know where they go. Next remove the screw at the top of the metal shell pickup and pull back on the shell to disengage it from the dryer. You can then remove it and inside is the heating element it is attached to the shell with 5/16 hex screws. Remove the screws and pull the heating element out of the bottom of the metal shell. Look closely and you should see the heating element break. The element is a coiled wire and when it heats up the wire actually grows in length and when it is off it cools and shrinks this causes fatique and the wire breaks over time. If the wire is broke replace the element. Look very closely use a pencil to move the wire slightly it is sometimes very hard to see the break. If broken replace the element and make sure not to touch the new element with your fingers this can case premature hot spots which causes the element to fail prematurely. If the wire is not broken then the thermal limit attached to the metal shell that holds the heating element is bad. Before doing any of the above you should look at all the wires in the back of the dryer and look for burnt or broken wires replace or repair them and check the dryer before any other repairs should be entertained. Before replaceing the back on the dryer clean all of the lint out of the back of the dryer and out of the dryer vent. This is very good insureance for the future of your dryer. Good Luck and I hope this is useful.
Sep 28, 2010 | Kenmore Dryers
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Water is hot but doesn't last long.
Your upper element is burnt out. open top cover, turn power of at breaker panel,drain hot water tank . remove black and red lead wires from the element use a socket to un thread the 3000watt 240 volt screw in element. re install the new element atach wires to element. Fill tank with water before turning on power or you will be replacing both elements very shortly
Feb 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hello there:
f your dryer doesn't heat, check these: Heating element Thermal fuse Wiring f you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) c5f4c5f.jpg
Feb 12, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Why isn't my dry grtting hot?
Check the house circuit breaker pair for the dryer--push off, then on. If no help, measure the voltage at the two slanted slots in the power socket. It should measure ~230 volts AC. If zero, either one of the breaker pair is bad, or there is an open wire between the socket and the breaker panel. If reads 230 volts, the problem is within the dryer--usually the heating element. The drum must be removed to get at the element.
Oct 11, 2009 | LG DLE2532W Electric Dryer
Speed Queed AEM677W2 dryer does not blow hot air
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams for DIY assistance.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Firstly, ascertain that you have made a positive heat selection, then read on.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 12, 2009 | Speed Queen Dryers
How do you open my dryer so I can look inside so I can see why my dryer is not getting hot air
visit youtube.com and type "do it yourself" and dryer repair in the search window.. there are some awesome kenmore repair videos online there....they'll take you step by step... have a blast!
Jun 11, 2009 | Kenmore 62872 Electric Dryer
Dryer won't dry
Without a meter there is not much you can do but a couple things to try , 1st turn the breaker off , when turning it back on push the breaker switch firmly in toward the panel then check for heat . the breaker may be running only half power and not supplying the heater [bad breaker] , the next thing is the temp. fuse on the heating element case. take the ;arge back panel off of the unit , you should see the element case on the right , it should have 4-6 red wires going to it , the fuse is located at the top of the case , remove the 2 red wires from it and slide them together then use electrical tape to tape them carefully power unit back up and test for heat , if it is working now you most likely have an exhaust problem , check the airflow where unit exhaust. let me know if you have any other questions.
Phil
Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 90 series model 110 60902990
There is a thermal fuse in the back of the dryer, its usually white plastic, usually with 2 lite blue wires going to it.its probally blown...you can check it with an ohm meter......but if it is blown make sure you check the vent hose to make sure it aint kinked off that usually causes them to blow. if it aint that, be sure to make sure the heating element aint shorted to the heater box.or the thermostats aint stuck....the thermal is a safety feature and something caused it to blow
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Fridgeidaire clothes dryer
I will try this again i don't think i posted it properly.
On the power cord where it connectes to the dryer make sure the red and black wire goes to the outside screws (L1& L2) the white goes in the middle and the green goes to the dryer cabinet.
If you have the red or black going to the middle one it will trip the breaker.
Oct 06, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
56 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
