Question about Compaq Presario 700 470024-192 Notebook
Satellite laptop battry don't charge
My laptop no start with out adapter when the laptop is start working the batry of the laptop not charging. the laptop is not work with out dc adapter.
  • 2,973 Answers
Friend, What you have described about your laptop clearly indicates that the battery is dead. Please change it. I too am facing the same problem but I cant change it because I am stuck in a very remote hill top in India where I can get thru to you with my mobile being used as the modem. My laptop is over five years old.
Posted on May 31, 2010
  • 2,404 Answers
Take out the battery and only hook up the AC Adapter. If the laptop turns on then that means the adapter is working. Now hook up the battery and see if it charges. If it doesn't then that means the battery is bad.
Try another battery, if the new battery doesn't charge then that means that the AC Adapter is bad because its not putting out enough voltage to charge the battery.
Suzuki raider 110 battery won't charge and engine won't start. how do i fix these problems? Pls help.tanx
most batteries are 12v. borrow a spare battry from someone or use 12v dc adapter to charge the battry... check the polarities and you can use the 12v dc sharger as power souce to auto start the bike
Aug 05, 2014 | Motorcycles
I have a 96 s10 blazer with a 4.3 starts hard idles rough wants to stall has misfire and when I turn on the blinker the battery gauge moves with it and when in park if I Rev the motor the speedometer and...
Have you checked the voltage at the batry when running? Sounds like alternator is not working properly. The battry is only used for starting, once started the alternator runs all the accesories & charges the battry. If not chargeing the vehicle will **** battry power. You may have a good battry surface voltage but a bad battry. The battry should be load tested as well.
Jun 24, 2012 | Cars & Trucks
Hi sir my mobile phone is GT-15801 and its batry finish in some hours after full charged
Hi
SIR simply your phone battry are not working or not properly charged . Some tips i will give you I hope this tips will help you.
(1). Please do not select the maximum volume.
(2). Please do not put your phone on vibration mode.
(3). select no light from the day hour.
Thanks you.
Mar 27, 2011 | Samsung Cell Phones
Confuse the function of the laptop adapter Toshiba satellite pro
The AC Adapter has to be used which is compatible with the particular model of the Notebook. You can refer the User Manual came with the Notebook to know the exact model number of the AC Adapter. To confirm whether the AC Adapter is working or not you can check the LED light of the AC Adapter, if the LED is glowing then it is working fine.
The function of the AC Adapter is to charge the Battery of the Notebook.
You can also use the Notebook by connecting the AC Adapter while it is charging or when it is fully charged.
Mar 27, 2011 | Toshiba Satellite Pro L300 Notebook
It is no longer charging
there are certain issue
  1. Check the plug, if it is working
  2. Check adapter indicator , if indicated is glowing?
  3. Remove battery of your laptop & connect adapter directly ,See if your laptop gets the power
  4. Replace with another adapter, if it starts charging then definately it was a charger problem.In that case you need to buy another charger...
  5. If you laptop does not charg with another charger, then ther might be problem with the laptop..
let me know , if it works....Other wise we will find another troubleshooting steps....
Thanks
Pandeep
Mar 07, 2011 | Toshiba Satellite L305-S5908 Notebook
My toshiba satellite pro doesn't work , even with charger in , it doesn't turn on , its like all the power is gone :o ?
You may have a bad DC connection:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Toshiba Satellite A60 Notebook
How do I know when my wii remotes are all the way charged up? What does the blue light mean? How do i know when its working properly?
the blue blue lights mean that the battries all charged up.if you cant connet good to the hand thing that means the wii remote needs batries hope i help!
Apr 11, 2010 | DreamGear Charging Dock Dual for Nintendo...
Toshiba satellite a100 wont take on power or boot
the battry is not charging and check the model of the battry whether its the same
Nov 16, 2008 | Computers & Internet
Toshiba LAPTOP m65-s821 wont turned on
dear sir.
yes u have to do one thing first you can do yr laptop need to setup some physical settings if you know bout hardisk located then plug out and then on your laptop if laptop is working then turn off it and take battry of then plug harddisk in then re start yr laptop do same as RAM if u know how u unplug both device and be carefull... it's help u..:)
Thanks
please vote
jo_chinmay
Jul 07, 2008 | CMB T43 750 Notebook
Compaq Presario 700 470024-192 Notebook Logo
43 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
