How do i reset the waste pad counter overflow of epson tx700w
    Problem Solver:
  • 8 Answers
Like above solution was taken from 2manuals.com site - there is now new solution to reset the Epson waste ink counters - Reset Utility for waste inks counters - WIC Reset Utility. Sopports all inkjet Epson printers.
Download it here - http://www.2manuals.com/WIC/WICReset.zip
You can download and check the Waste Ink Counters free.
Posted on Jun 29, 2011
    Scholar:
  • 75 Answers
Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
  1. Turn off your printer, ensuring that the print head is at it’s home location and locked in place as normal;
  2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
  3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer’s power switch was ‘on’ - switch it off and return to step 1;
  4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
  5. When the paper-out LED flashes, release the buttons;
  6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
  7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
Procedure 2
  2. Hold down the paper feed button only;
  3. Turn on the printer;
  4. As the paper feed light starts flashing, release the button;
  5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
  6. Allow printer to complete it’s processing, then turn off for a few seconds, and back on again for a newly working printer!
Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
  1. Switch off printer with panel switch;
  2. Switch off printer at mains switch - leave off for 20+ seconds;
  3. Hold down roll feed and sheet feed buttons;
  4. Switch on at mains;
  5. Switch on at printer panel;
  6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
  7. Switch printer off and then, after a few seconds, on again at mains switch;
  8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
  9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
  10. Release the roll feed button and all should be well.
Procedure 4 - Cheat with Software Reset Methods! There is a software reset method that can be used to reset ink levels. It is recommended to use in Epson service centers. Each printer model has specifyed service (adjustment) program which has such option like Reset Protection Counter when you need to reset the value of Wate Ink Counter. You can learn more about software reset method at this link: About Service Programs.
This programs can be used to reset a number of counters in the printer, etc. Please note that CIS users should probably steer clear of any resetting of cartridge ink levels in the printer, and you will probably need to look for the ‘Protection Counter’. Due to the risks of resetting this protection counter, it may be preferable to use the software once to reset the counter, then uninstall it so you do not inadvertently reset the counter more than once.
According to it’s own readouts, it did reset the ‘protection’ counter... but pretty much did so of it’s own accord. It then seemed to interfere with printing! However, the access to advanced cleaning function control etc looks useful. Nevertheless - use with caution as per the notes above!
Reset Error Light Conditions Summary OK - so whilst we have heard this resolves the problem, it may not do so for you, and whilst we have heard that the ink-pad error is most likely way before the ink pads are actually full, we think it will be OK. However, you should be aware that IF your ink pads were full then resetting the counter on the printer without replacing the pads could ultimately cause damage to your printer and surrounding areas as inks starts to pool inside the printer base and potentially leak out. We suspect that this will not happen for the vast majority of people, but it is certainly possible. We have now heard of this occurring for a couple of people.
Instructing you how to dismantle the printer to examine the waste ink pads is currently outside the scope of our support assistance (though we have done this task ourselves with minimum fuss). You may like to refer to our Service Manuals page and Spares Printers Parts UNICOMP site.
Reset waste ink counter by adjustment program
Since your printer consumes ink not only for printing but also for other operations like cleaning, a certain amount of ink is wasted and it is collected by the waste ink pad. Therefore, the printer counts the amount of waste ink.
Once the amount of waste ink reaches the predefined limit, the printer indicates "MAINTENANCE REQUEST" and the waste ink pad should be replaced. Also, you must reset the maintenance error condition and the waste ink counter value stored in EEPROM on the mainbord of the printer.
The adjustment program enables you to perform maintenance and adjustment functions such as:
  • EEPROM initial setting
  • Ink Pad Counter reset
  • Initial Ink Charge
  • Head ID Setting
  • Top margin Adjustment
  • Bi-D Adjustment
  • USB ID Input
Note: This example shows you how to reset waste ink counter of Epson R280, R285, R290 printers. Other printer models may have different set of functions, and you must doublecheck the service manual for a specific printer that you are going to troubleshoot.
Warning: misuse of a program may damage printer's EEPROM! Run the program under Window XP only.
How to reset waste ink counter by adjustment service program for Epson R280, R285 and R290 printers.
1. Download the Epson R280 adjustment program from www.2manuals.com.
2. Save archive and unpack by WinZip
3. Change PC date to April 10 2008 or another date you need. Just doubleclick in the right bottom and change date.
4. Run AdjProg.exe prograhow do i reset the waste pad counter overflow of e - run1.gifWindows XP. Press ACCEPT.
run1.how do i reset the waste pad counter overflow of e - mode.gifss=
5. In new window check Particular adjustment mode.
6. Then chehow do i reset the waste pad counter overflow of e - check1.gife ink pad counter option.
CHECK for checkin counter value.
8. To reset waste ink counter check 2how do i reset the waste pad counter overflow of e - reset3.gif press INITIALIZATION.
9. Then press &icirhow do i reset the waste pad counter overflow of e - finish.gif/b>.
10. Resetting process is for few seconds and looks like:
11. For finishing power off the printer. The data will save up in the printers EEPROM. There will appear message:.
Posted on May 31, 2010
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
How do I reset the waste ink pad on my Epson Discproducer PP-100
The most easy way to reset Epson PP-100 Waste Ink Pads is to use WIC Reset Utility and reset waste ink counters by Yourself.
There is video tutorial on Youtube - How to reset Epson PP-100 Waste Ink Pads Counters:
Jul 03, 2014 | Epson Office Equipment & Supplies
Reset Waste Ink Pad for Epson
You Go To This Link And after Follow The Steps.
http://www.youtube.com/watch?v=3Sgl5LOWKi4
Thanks And Regards,
Piyush Gohil
Nov 21, 2013 | Epson America Epson Maintenance Box for...
The printer's ink pads are at the end of their service life. Please contact Epson support.
As the error says the waste ink pads are at a point where Epson have estimated they need to be changed... However you do have a couple of options.
1. You can take it to a service centre and get them to reset the waste counter and change the pads (check that they will/have actually done this though as many just reset and leave the pads to overflow!).
2. Reset the waste counter and change the pads yourself (if the printer has replaceable pads - as many of the newest printers do) or fit an external waste ink tank like a Printer Potty.
Can't be any more specific than that though as you've not indicated which printer model you have.
Aug 07, 2013 | Epson Printer
Nov 30, 2011 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
Apr 26, 2011 | Epson Printer
What does it mean when the power light and the printer light are blinking on an Epson c60 model?
If all the Led's/Light's are blinking/flashing on an Epson Printer, that indicates "Maintenance Request Error". The maintenance request error is actually a "Waste Ink Pad Overflow Error". Normally your remedy is to replace the Waste Ink Pads with a new ones and then reset the INTERNAL WASTE INK PAD COUNTER...The need to replace the waste ink pads is measured by the amount of ink uses, which is determined based on the number of Head Drive Pulses, accumulated in the waste ink counter. When the total quantity of ink deposited onto the waste ink pads, during cleaning and flushing, reaches the set limit, the printer generates a maintenance request error and stops printing. If you just reset the counter and don't replace the pads, then your printers old pads will eventually overflow and normally start leaking ink out the bottom of your printer.I know this information is not much help, but at least you will know what your ERROR is.
Feb 26, 2010 | Office Equipment & Supplies
Reset waste ink counter on Epson C60 printer
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can restore your printer to a working condition immediately by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Feb 24, 2009 | Epson Stylus C60 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
5,613 people viewed this question
jasbo
jasbo
