Question about Raypak Free Hydraulic Lift Gate Delivery - No L...
My raypak heater won't relight and the pilot is on
The heater shut off when the water flow was stopped. Now it won't turn on even though the pilot light is on.
  • 8,404 Answers
For the heater to burn, there must be water pressure and flow - and the heater must know of it. It is not enough that you know the pump is on, the heater must know it. Check your heater's water pressure switch.
What about the filter pressure ... high filter pressure would indicate need for a backwash. dirty filters slow the water flow. If your filter normally runs at 20 PSI (when clean) it should be backwashed at 30 PSI, rule of thumb = 10 psi over 'startup pressure'.
Your heaters job is to heat the water ... think of it as a very agressive bully. The water is absolutely necessary to keep the bully in check.
Posted on May 31, 2010
Brand new Raypak gas pool heater started up ok but when shut down for the night electronic pilot won't kick in to start heater.
makesure gas is on, gas valve also turned on. check to make sure you are gettin proper voltage to igniter. ensure proper water flow from pump.
Aug 02, 2013 | Pool & Spa
Heater does not turn on
If you have a gas hot water heater that won't stay on, check to see if pilot light is out and relight it if it is. If you have an electric hot water heater that won't stay on, then you should have an electrician check the wiring.
if you need an auto tool you can click here: chinasinoy.com
Nov 05, 2012 | 1990 Toyota Corolla
Enviro temp hot water heater. 1 week ago pilot out. Able to relight but would go out again once water heated to temp. Replaced thermal couple (tc) with same result. replaced gas therm/valve (t/v). ...
Remove your entire pilot assembly from the heater and gas valve. Remove the aluminum gas line that feeds the pilot assembly. There is a small orifice inside the pilot assembly that may or may not fall out when you take the line off. If it does not fall out remove it and be sure that the very small holes in the top of it are clear. It sounds to me like even though the flame is blue and in contact with the thermo-couple, when the main flame turns off it causes the pilot flame to wave away from the thermo-couple thus shutting it down due to a weak pilot. I have run into this several times and should do the trick.
Feb 02, 2011 | Water Heaters
Do we need to shut off the gas or pilot light when draining out sediment on our gas water heater?
Yes you should shut off gas valve & water in to tank. Drain tank fully then turn on water & relight pilot.
Jan 24, 2011 | RELIANCE ELECTRIC WATER HEATER
Why frequently relight my pilot?
check for water run off from above or sprinklers directed at heater. A high wind stack may be needed due to heater location. Millivolt models have a thermocouple or pilot generator that may be faulty or weak. Loose or rusty connections of the thermocouple to the gas valve or loose coil connection, or short in these wires can shut off a pilot.
Aug 27, 2008 | Raypak REFRACTORY KIT
Raypak Free Hydraulic Lift Gate Delivery - No L... Logo
231 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
