Question about DCS BGB36BQARN (NG) Stainless All-in-One Grill / Smoker
Install question for clearances to combustiable material
I have a built in area for my new grill and it has 6 inches of rock on the back side of the grill along with a 4 inch air space before the rock is this enough space before the wall material??
  • 8,404 Answers
Rock ... as in stone? ... or rock as in sheet rock? Your new grill no doubt came with a installation guide and there should be guidance in that guide about clearances. If your grill was not intended to be built in - it will say that in that guide.
I am not familiar with this particular model, generally speaking, I would say if this is outside and you have 4 inches between the grill and rock (rock as in stone), your stone shuld not be in danger though it may get warm.
Thanks for your interest in FixYa.com
Posted on May 31, 2010
  • A Miller May 31, 2010
    thanks for the three thumbs up ... despite my spelling error ... your stone shuld (ops ... should ...) not ...
Hey there I need the exhaust and Intake(valve) clearance for a komatsu 300-6 please
note Perform the valve clearance check and adjustment at the engine cold state. 1.Remove all of the ignition coils. 2.Remove the cylinder head cover.
caution Turn the crankshaft always clockwise. 3.Turn the crankshaft clockwise, and align the timing mark on the exhaust camshaft sprocket against the upper face of the cylinder head as shown in Figure. Therefore, No.1 cylinder goes to the compression top dead center. 4.Using a thickness gauge, measure the valve clearance with the arrow shown in Figure. If deviated from the standard value, make note for the valve clearance.
Standard value:
    Intake valve 0.20 ± 0.03 mm (0.008 ± 0.0012 inch)
    Exhaust valve 0.30 ± 0.03 mm (0.012 ± 0.0012 inch)
5.Turn the crankshaft clockwise 360 degrees, and put the timing mark on the exhaust camshaft sprocket in position shown in Figure. Therefore, No. 4 cylinder goes to the compression top dead center. 6.Check the valve clearance with the arrow shown in Figure. In the same procedure as 4.
7.If the valve clearance is deviated from the standard value, remove the camshaft and the valve tappet. For the camshaft removal, refer to Camshaft Removal and Installation . 8.Using a micrometer, measure the thickness of the removed valve tappet. 9.Calculate the thickness of the newly installed valve tappet through the following equation.
A: thickness of newly installed valve tappet
B: thickness of removed valve tappet
C: measured valve clearance
Equation
    Intake valve: A = B + [C - 0.20 mm (0.008 inch)]
    Exhaust valve: A = B + [C - 0.30 mm (0.012 inch)] note The valve tappet ranges 3,000 - 3,690 mm (0.1181 - 0.1453 inch) and has 47 types per 0.015 mm (0.0006 inch). The thickness below a decimal point is stamped on the reverse side of the valve tappet. 10.Install the valve tappet selected through the procedure 9, and put the camshaft in position. For the camshaft installation, refer to Camshaft Removal and Installation .
    11.After installing the timing chain, measure the valve clearance using the procedure 3 to 6. Confirm the clearance is within the standard value.
    caution Completely remove all the old FIPG, which might be remaining among the components. 12.After completely removing the liquid gasket adhering on the timing chain case, cylinder block and cylinder head, degrease them with white gasoline.
    caution The cylinder head cover should be installed within 3 minutes of applying liquid gasket.
13.Apply a 4 mm bead of liquid gasket as illustrated.
Specified sealant:
    THREE BOND 1217G or equivalent
14. Install the cylinder head cover and tighten the tightening bolts using the following procedures.
(1) Temporarily tighten to the following torque in order shown in the illustration.
Tightening torque: 3.0 ± 1.0 N·m (27 ± 8 in-lb)(2) Tighten to the specified torque in order shown in the illustration.
Specified torque: 5.5 ± 0.5 N·m (49 ± 4 in-lb)15.Install the ignition coils.
Jan 23, 2017 | Cars & Trucks
Tip
HOW TO MAKE YOUR OWN ROCKING CHAIR CUSHIONS
If your rocking chair cushions are looking weary and old, you don't need to buy a new rocking chair. If you can sew, follow these simple tips and re-upholster your existing cushions or make new ones altogether. Your friends will be congratulating you on your brand new rocking chair.
1. Draw a design for your rocking chair cushion. If you are new to this, keep it simple with a rectangle or square design.
2.
Measure the area for the cushion, taking both length and width and then add 3 cms to each, and this will be the amount of fabric you need.
3. When you buy or cut out the cushion padding, use the original measurements ie without the extra 3cm you added on to the material.
4. Your padding material should be between 1 and 1 and a quarter inches thick.
5. Now cut out your cushion fabric. You need 2 pieces for each cushion. Make sure you keep the lines straight and that they are both exactly the same .
6.
Start at a corner and sew a piping (double seam) along the edge. Then sew the 2 connecting sides to that new seam and this should form a pocket that is connected on 3 sides but has an open top.
7.
Now stuff the cushion. Don't rush this part. Make sure none of the foam is folded over or squashed up inside the cover.
8. Now sew the final seam together. It can be a bit tricky so make sure it's lined up properly.
9.
Once you've finished the basic cushion you can always add extra details such as trimming or tassles.
Enjoy!
on Aug 21, 2012 | Furniture
We purchased 4 burner discovery as a built in for outside. In the Built-in unit is is requiring some brackets for the side to rest on the sides of the brick work. Where can they be purchased as they did...
If you purchased just the grill head, for a built-in installation, the Trim Kit/Brackets should have come with it. Or perhaps, they're already attached. If not, contact Beefeater, as another grill manufacturer's parts may not fit your grill head.
Jul 09, 2011 | Beefeater Discovery 4 burner Grill
I have an old Efel Kamina wood stove that I want to install in a new structure that does not have a chimney. I need the manufacturer's specifications to determine the distances from combustible materials...
From an insulated wall - 30 inches. Not insulated - 38. We have one as well and are trying to find out information about it.
Southport Stove Inc. Serial # F90309 ICBO 3 500 Another number: 079-66 It's a Kamina.
Any information would be great!
Sep 14, 2010 | Heating & Cooling
We installed a Woodchief wc 100c woodstove and i
Hello, I have the same model. The plate on the back say's,install with min installation clearance's side and rear wall 18 inches fire door end 36 inches front 48 inches above 51 inches flue pipe 18 inches install on non combustible and non conducting base of 9/32 inch min thickness that extends 6 inches beyond the sides and 18 inches beyond fire door side. circulating fan type FF-100
Feb 23, 2010 | Heating & Cooling
Can built in fridges and freezers cause damp in walls if only ventilated from the bottom
Not usually as long as it is the type with the condenser underneath and has a fan. The type with the condenser up the back with no fan need to be ventilated on the top with at least 6 inches clearance for air to flow freely.
Jan 03, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
One side of the grill cooks on lower temp then the other side.. tried new burners but that did not help, what can i do
close your burners up sounds like they are open to much also you make not have enough gas going to the grill, if this is your grill in the picture then you need a half inch line for it
Aug 13, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
DCS BGB36BQARN (NG) Stainless All-in-One Grill / Smoker Logo
137 people viewed this question
Top DCS Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
joel920368
Are you a DCS Grilling Expert? Answer questions, earn points and help others
