Question about Acer Aspire 4720 Notebook
There is a sudden change in the hue of my lcd- acer aspire 4740
There is a sudden change in the hue of my lcd monitor but that sudden pinkish change in hue just takes about less than a minute, then all is back to normal. that sudden change in hue happens about twice everytime a opened my notebook
    Master:
  • 633 Answers
It can be an issue with the display cable or the LCD panel itself.
U will have to check with a local tech.
Posted on May 31, 2010
Acer aspire 6930 LCD replacement is foggy and distorted
hate to say this but it sound like you need another screen replaced
Jul 29, 2012 | Acer Aspire Computers & Internet
Moniter has too much red
On the monitor controls (usually accessed through the menu button) there should be options to change the color hue and saturation
Jan 08, 2012 | Acer AL1916W 19" LCD Monitor
Asus laptop and red shadows on letters and bad picture. is this a lcd inverter problem? External monitor works ok.I check lcd panel cable and replace lcd panel but all same
Yep, it's the inverter. Anytime there is a red or pinkish tint or hue you know it is the inverter. Usually the inverter is very easy to change. I would buy one on eBay for your best price...
Good luck!! EJ Kudelka
Oct 18, 2010 | Computers & Internet
I have Sanyo 42" flat screen LCD TV Model #DP42647. The color suddenly started appearing with pinkish hues. Any bright spot takes on a pink color and has no distinct features. I have tried to manually...
Hello; I am John at J. D. Electronics, Poland Maine. This problem is very likely caused by a defective LCD panel. This part is very expensive! Aprox $ 1000.00 from Sanyo . Obviously, that is more than the set sold for.
Oct 13, 2010 | Sanyo Televison & Video
Acer netbook AO751h screen does not work, external monitor works fine.
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
Hope this helps.
Sep 20, 2010 | Computers & Internet
Pinkish hue now adjusting the green has no effect all red colors are yellow now
Check all the pins at both ends of the cable, also try it with another PC to make sure it is not the video card paroblem. Please post back the result for further help.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Aug 30, 2010 | HP f2105 21" LCD Monitor
When I turn my Acer on, the light comes on but the monitor stays black. This happens even if I have it plugged in to the ac adaptor. Is the monitor broken? It has been plugged in for charging for some...
The problem here is the Acer Aspire One suffers from the black screen of Death, it's a BIOS error I have three Acer Aspire One's and I have had this problem and fixed it.
Here’s what you need:
  1. USB Memory stick (just need one as low capacity as 128mb)
  2. Another PC with a net connection
  3. WinZip, WinRAR, or some other program that can extract zip files.
  4. A quick visit to www.acer.com
  5. Your Acer Aspire One, that will power up/turn on, but the screen does not come on/stays black.
And here’s what you do:
  1. Go to www.acer.com and go through the DRIVER support pages until you get the Aspire One driver page for your relevant Aspire One model (110 or 150 or 751)
  2. Click on the tab on the download area that reads ‘BIOS’ even if it looks like you can’t click on it (their site design grays it out but it’s there) and download the BIOS file numbered 3310 (it might have changed version recently but do it) and don’t worry, you can trust this file, as it’s from Acer directly.
  3. Extract the zip once downloaded and find in the DOS folder the files ‘flashit.exe’ and 3310.fd
  4. When you’ve found them, rename 3310.fd to ZG5IA32.fd and put this renamed file and ‘flashit.exe’ onto the USB memory stick
  5. Put the USB in the Aspire One and hold the keys ‘FN’ (function) and ‘Esc’ (escape) and keep them held when you turn the laptop on
  6. Watch the power button and when it starts flashing, press it once (DO NOT DO ANYTHING ELSE)
  7. You should notice the USB (if it has a light) blinking as well…
  8. The netbook has started ‘flashing’ the BIOS and after about 7 minutes, the netbook should shutdown and reboot itself and VOILA! The screen should turn on just fine.
This is tried and tested. It took me three times because I messed up step 6 a couple of times but my netbook worked after the third attempt.
May 21, 2010 | Acer Aspire One PC Notebook
The whites are not as white and there is starting to have a slight pinkish purpleish haze around the edges around the screen its not bad yet but I have tow and you can see that it is not as bright as the...
When an LCD starts getting pinkish to redish hues, the screen is starting to fail. You are in the biggining stages of losing the screen. There is no repair....only replacement.
Jan 16, 2010 | Apple Cinema Display 23" HD Monitor
N0 or Very little backlight on Samsung SyncMaster740 17" Monitor
back light is going bad. if you see a pinkish hue on the" checking signal" box on screen when it comes on. Should be white.
Feb 22, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor colours get pinkish red
The lamps have not failed as you believe Steve. If they fail, then a protection circuit inside will shut them off all together.
Acers have a habit of capacitors failing. This in turn sends dodgy power to the inverter circuit and through to the lamps.
This is not a design flaw, it's just age. Capacitors can die early of course, but it's not common for them to go before the warranty period is up at least. Normally 3-5 years is what you can expect from them.
If you understand electronics then the job will be easy, if not have your local TV tech give it the once over before real damage is done.
Nov 07, 2007 | Acer AL1714 17" LCD Monitor
Acer Aspire 4720 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
