Question about Garden
Ryobi EX26 will not start. I replaced spark plug and primer bulb. Even used starting fluid. It will fire up for a few seconds and then die. Help please!
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 31, 2010
I have replaced spark plug, gasolines w/fuel filter, and carburetor but ryobi s430 still won't start.
Make sure that all of your fuel lines are good with no leaks and cracks. Ditto for primer bulb. If all ok, then you need to clean out carb, or get a kit for it.
Apr 10, 2017 | Ryobi Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have just aqutred a used Ryobi rcs3535ca Thats proving impossible to start, it came with no manual or instruction book can you help?can I also purchase instruction and manual books? Regards CB
As this machine may have been unused for some time, drain the fuel tank and fill with fresh fuel, if no better, remove the spark plug and test for a spark with a suitable spark tester, if you do not have one, use a new spark plug, earth it to the cylinder, away from the spark plug hole, if it has no spark then a replacement ignition unit will be required, if there is a spark, is the plug getting wet with fuel, if not we have a fuel starvation issue, remove the fuel hose from inside the fuel tank and replace the filter on the end, if the plug is copletly soaked in fuel, it is flooded, put the ignition switch to off, now crank the engine ten or so times, leave the saw to dry out for an hour, replace the plug and go through the starting procedure again. Starting procedure on most machines are as follows, switch the ignition on, pull the choke fully out, if it has a fuel primer press this as many times as it takes to 3/4 fill the bulb, crank the engine until it fires once ( do not continue to crank with the choke out ), push the choke fully back in, now crank the engine until it fires up and runs.
Feb 10, 2011 | Ryobi Garden
My ryobi trimmer want hit a lick. The spark plug is firing. But will not hit. I tried a small spray of starter fluid in the carb and still nothing. Could this be the fly wheel is out of time ?
Try removing the air filter...hold throttle open and either squirt or pour about a teaspoon of FRESH fuel mixture into the carb throat...be sure that the fuel enters the cylinder through the throat....hold the throttle open and pull start handle and if you have spark it should start and run for a few seconds...if not you may have an electrical problem (weak magneto = weak spark ) ... if it starts and runs your problem may be in the carb (clean or rebuild) DO NOT use starter fluid to do this test...it is too volatile and you may blow the head right off your machine...also check the four screws on the rear cover (the four screws above the gas tank) they may have loosened and are allowing an air leak at the rear of the crankcase. these covers are plastic and have a tendency to warp under the heat generated by the engine. There is a gasket between the cover and the metal crankcase, and if the cover is warped it may be letting air through into the case....can cause a no start situation. do a cursory inspection of your fuel lines , fuel filter, and the primer bulb and check tightness of the carb bolts as cracks here also allow air leaks in the fuel system. If you've been using starting fluid to try and start your engine you might also want to check the head gasket and front crank seal to make sure you haven't blown a hole in them...good luck...;-D
May 15, 2010 | Garden
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi EX26 dies when hot, won't start, then when cool starts
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Jun 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
Jun 23, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
1,448 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
