Question about Microsoft Windows Vista Ultimate Edition
Ved opstart af window defender
Flg. fejlkode 0x8007042d
Tjenesten starde ikke p.g. af logon fejl
  • 128 Answers
From your description, I understand the issue to be: you received VSS error 0x8007042d.
I. First please re-registry the following DLLs to see if it helps:
1. Stop the Volume Shadow Copy service: Open a command prompt and change
directories to \WINDOWS\system32 (this is important when you begin
registering the DLLs):
net stop vss
2. Then register the following DLLs and services (be sure you're still in
the WINDOWS\system32 directory at your command prompt):
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 /i swprv.dll
regsvr32 /i eventcls.dll
regsvr32 es.dll
regsvr32 stdprov.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Start the Volume Shadow Copy service by running "net start vss", do a test
backup and see how it goes.
II. If the issue persists, Let's perform these troubleshooting steps:
1. Make sure you can use OSQL to connect to every running instance of
SQL/MSDE on the box, if you can not disable all of the instances.
You can find all of the instances installed on your server, by looking at
this registry value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL
Server\InstalledInstances
The syntax would be "OSQL -E -S <servername>\<instancename>
For example OSQL -E -S server\SharePoint
If you can't connect to the database, then it will cause this type of
failure.
Also make sure that each of the SQL/MSDE instances is either running under
the Local System account or a Domain Admin account.
2. The issue may occur if there is corrupted data on the drive to be backed
up. Please run CHKDSK on each drive with the /f switch to fix the errors on
the disk (if there are any).
3. Per my experience, this issue can be due to VSS thinks the system is
still in setup process. Please perform the steps below to check the status.
WARNING: Using Registry Editor incorrectly can cause serious problems that
may require you to reinstall Windows. Microsoft cannot guarantee that
problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk.
Open the registry and locate the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\Setup
Ensure both registry values are set to 0:
- SystemSetupInProgress
- UpgradeInProgress
4. If the issue still happens, reinstall COM+ by following these steps:
A. Backup and then delete HKLM\Software\Microsoft\COM3
B. Boot to Recovery console and rename clbcatq.dll to ~clbcatq.dll. Be sure
to use the tilde.
C. Boot to normal mode and in Control Panel, open the Add or Remove
Programs tool, and then open the Add/Remove Windows Components tool. Do not
make any changes, just click "Next". This reinstalls COM+.
NOTE: You must have your Windows Server 2003 SP1 files available during
this step.
Hope above information helps! I am happy to be of assistance to you and
look forward to your reply!
Posted on Jun 02, 2010
Gaggenau ovn fejl E107 hvem kan hj?lpe, jeg har pr?vet at slukke den og pr?vet at lukke for b?rnesikring/l?s Gaggenau oven error E107, have tried to turn it off and to close the parental lock/unlock
L?g i Model # om st?tte
http://www.gaggenau.com/us/support/downloads/operation-manuals
2. Brug Google Translate iTool til at overs?tte en hel webside
Hvis du ikke kan finde en knap til at overs?tte websiden, kan du bruge Googles gratis online overs?ttelse tjeneste til ?jeblikkeligt overs?tte det til et andet sprog. Du starter ved at skrive adressen p? den webside, du vil overs?tte til den hvide boks i Googles v?rkt?j. Google med automatisk bestemme sproget p? siden, og brug rullemenuen til at v?lge, hvilket sprog du vil overs?tte siden i.
Klik p? knappen gule overs?tte, og du vil blive taget til en ny side med overs?ttelsen.
http://itools.com/tool/google-translate-web-page-translator
kan bruge Google Translate til at sp?rge og l?se https://translate.google.com/
Nov 23, 2015 | Gaggenau Ovens
Kan ikke installerer outlook (Vista )
Jeg har skrevet en "clarification request", kunne godt bruge lidt flere informationer.
Jeg har et par g?t.
Enten har du en forkert udgave af Office 2003, hvor Outlook ikke er med, f.eks. Student Edition.
Hvis du har en pr?veversion af Office 2007 installeret p? computeren kan du ogs? komme ud for at den skal afinstalleres f?r du kan f? Office 2003 til at fungere ordentligt.
Mar 09, 2011 | Microsoft Office Word 2003 for PC
How to do Printer Mapping through log on Scripts
Goto Active Directory Users and Computers in Administrative Tools
Right Click Users Container > Click Properties >Click Group Policy tab > then click Open
Right Click on Grop Policy Ojects > Click New > Set the name Accordingly > Right Click and then Edit the Policy
Then Expand the User Configuration > Expand Windows Settings > then click on Scripts
Right Click on Logon > click Show Files > click File > New Text Document
Copy and paste information below and Edit Appropriately > then Save As a Batch File (.bat)
@ECHO OFF
ECHO Executing the Printer Installation - Kanata Colonial
:: SET PRNTSRVR=control1
:: Mapping Printers
IF EXIST "%USERPROFILE%\PrintersInstalled_00.flg" GOTO DONEPrinter
::IF EXIST "%USERPROFILE%\PrintersInstalled_01.flg" GOTO UPDATEPrinter
GOTO INSTALLPrinter
::UPDATEPrinter ::Del "%USERPROFILE%\17PrintersInstalled.flg" ::RUNDLL32 PRINTUI.DLL,PrintUIEntry /dn /n \\ServerName\PrinterShareName ::RUNDLL32 PRINTUI.DLL,PrintUIEntry /dn /n \\ServerName\PrinterShareName
:INSTALLPrinter REM Install BrightWell printers RUNDLL32 PRINTUI.DLL,PrintUIEntry /in /n \\%PRNTSRVR%\LJ4050 RUNDLL32 PRINTUI.DLL,PrintUIEntry /in /n \\%PRNTSRVR%\LJ4650
echo > "%USERPROFILE%\PrintersInstalled_00.flg"
:DONEPrinter ECHO "Printers Installed" :END
Jul 10, 2009 | Microsoft Windows Server 2003 Enterprise...
Acer aspire from vista to xp - Driver problems.
Hej,
UPS, ikke så godt, - Acer suporterer ikke WinXP for din model. -> det er noget af det vigtigste, -> at undersøge om den model computer man nu køber suporteres af både Vista OG WinXP.
Vista er lige så stor en joke som Mellinium var, det er også derfor at de allerede er ved at frigive et nyt styresystem, Windows7.
Nå, synd for dig, men her er ingen hjæp at hente, ikke engang til en landsmand, Sorry som vi siger på Dansk.
Det til trods, - for du fik et svar, håber jeg at du vil stemme (vote) "FixYa", - tak.
/Teis
Jan 14, 2009 | Acer Aspire 7720 Notebook
Returblekk n?r full
Hej Lars,
Jeg kan ikke finde noget der ligner din fejl beskrevet. Men, - er det en "gammel" tank du forsjøker at fylde blæk på?  -> så skal du kanske kjøbe en ny original tank.
Ellers kan du jo også telefonere Canon Norge HER: og spørge dem. Der findes ej spørgsmål lignende dit på Canons hjemmeside.
venlig hilsen /Teis Håber du finder svar! 6a71920.png
Ked af at jeg ikke kunne hjælpe dig
Jan 11, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Min router fungerer fin via kabel. men efter en reeset af routeren kan jeg ikke l?ngere logge p? tr?dl?st. Hvordan finder man en ny n?gle???
Hej Trille,
- generere nye koder?
Det bliver uden tvivl noget grusomt "giberish" = uforståligt :-)
Du kan selv lave din egen kode, og VæLG key 1, for der er desværre trådløse kort der KUN har key 1.
Nu da du så har fået sat en kode på routeren, skal du "bare" sætte den samme kode på dit trådløse netkort.
Model - og jeg kan hjælpe
Hvis ikke, - så ville det da ikke gøre mig det mindste hvis du "vote" "FixYa" :-)
arbejder på at blive Guru her på siden :-)
Dec 03, 2008 | Linksys Wireless-G Broadband Router
Fax
cannot copy of memory card glossy paper keeps jamming
Jul 31, 2008 | Brother Multi-Function Center® MFC-215C...
Microsoft Windows Vista Ultimate Edition Logo
282 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
