Monitor my compaq monitor keeps going to sleep mode soon as i turn it on
  • 385 Answers
Maybe it's because it's not getting a signal from the CPU.
Make sure that CPU is working on another monitor.
Thanks,
Lolita
Posted on Apr 08, 2008
Monitor keeps going into sleep mode
try a different monitor / tv (some have pc hookups) and see if it really is your monitor or your PC not providing a signal
Sep 02, 2014 | Compaq Computers & Internet
Hi,.. I was given a compaq FP 7317 with the tower, key board,...monitor keeps saying "going to sleep" when I finally got it all pluged in. HELP. HOW TO GET OUT OF GOING TO SLEEP?
To disable sleep mode in vista follow the steps
Go to start and type in the search box Power Options hit the enter button
On the Left side there is a panel Click Change when the computer sleeps
Click the drop-down box which says Put the computer to sleep and select Never
Click Save changes
Jun 28, 2011 | HP Compaq FP 7317 17" Flat Panel LCD...
I cannot get my monitor to work. as soon as i turn pc tower on, the light on monitor goes green then says its going into sleep mode. so i cannot operate anything on the screen at all, i have dusted the...
The problem lies in your ram. Pull the modules,swap their positions and reboot. The contacts are dirty and by removing them, they again make proper contact. Blow out dust. You will be fine.
Jan 22, 2011 | HP Compaq FP5315 15" LCD Monitor
Monitor keeps going into sleep mode and it won't turn on so i can use it.
Monitors go to SLEEP mode when there is no computer signal coming into them. As soon as a computer signal reaches the monitor, it will automatically wake up and show the images in the screen.
Mar 27, 2010 | HP Compaq FP5315 15" LCD Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Won't turn on... keeps "going to sleep"
Try another monitor on the computer, if it works properly then you know that the original monitor is the issue.
If the 2nd monitor gives you the same issue then you know its a problem with the computer. At that point, unseat and reseat the memory. Try another power supply. If the monitor still shows sleep mode then the motherboard in the computer is bad.
Dec 17, 2009 | Compaq FP 5017 15" Flat Panel LCD Monitor
As soon I turn on the computer, the monitor wil say it's going to sleep mode, nothing else appears. The cables are attached in the right slots.
hi
please try to take the computer in safe mode and then try to change the setting in display center and try to chage the value of power option and your computer monitor would be out from the sleep mode
Jul 07, 2009 | HP w1907 LCD Monitor
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
Modems
Apr 08, 2008 | Compaq 56K Modem
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
