Question about HP Officejet 5610 All-In-One InkJet Printer
I get a message 'print cartridge error'. nothing
I get a message 'print cartridge error'. nothing works.
  • 241 Answers
Try replacing the cartridge, if still getting error cleaning contacts in printer where cartridge sits with wet Qtip, also clean printhead on cartridge. Reinsert cartridge and see if this clears error message.
Posted on May 31, 2010
falter
  • 245 Answers
SOURCE: won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Posted on Apr 19, 2009
SOURCE: error message on printer:
Unplug from the wall, press power button three times, plug back in. After trying all other solutions, this one worked.
Posted on Oct 31, 2010
  • 18 Answers
SOURCE: Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Posted on Sep 21, 2007
  • 1019 Answers
SOURCE: incompatible print cartridges?
just click on them to say ok, and accept the unsupported cartridges ( if applicable ) do you get the choice.
certain printers, have an option in printer prefs, to change cartridges. check the cartridges are the same ( or compatable )
if the cartridges have a chip fitted, they need to be reset if recently filled.
hope this helps mike @ Compurepair.
Posted on Feb 20, 2008
  • 8 Answers
SOURCE: Ink cartridge (not) installed properly
For the Canon iP1800 printer are you sure you're using the 30 for black and 31 for color?
And make sure they "click" when installed. That should confirm that they're nice and tight in their ink compartments.
Besides that, maybe reinstalling the printer drivers could do something?
Posted on Sep 13, 2008
Hello, I replaced the cartridge in my HP 1020, now nothing prints. It runs through, but nothing prints. I put back the old cartridge and nothing prints with that now also. No error message, all green...
there ara no chips on the cartridge
when you get no print you need to refill it
check here how with no need of special tools
utube.png You-Tube video "iMiTopIVMxM" placeholder (do not delete) utube.png
Sep 30, 2010 | HP LaserJet 1020 Printer
Canon Pixma MP600 - Error Message U052 ... incorrect print head
Hi, sounds like you need new printhead, take a look on amazon for replacement Amazon com canon mp600 printhead I hope this was helpful. Cheers
Nov 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Cartridge Error 50C consult user guide. I
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Nov 10, 2009 | Lexmark X6170 All-In-One InkJet Printer
Error message saying incorrect print cartridge.
Check the Electrical contacts on the cartridge itself, they all need to be clean and nice and shiny to work properly. Make sure you haven't overfilled the cartridge too, this can sometimes cause problems. To be honest, the HP cartridges do 'wear out' after a few refills. when they go electrically dead, there is nothing you can do about it apart from buy a new one!
Oct 21, 2009 | HP PSC 1315 All-In-One InkJet Printer
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
I've tried trouble shooting "print cartridge error" plus print still in queue message. I've cleared both but messages still returns with copy, fax and scan lights blinking.I've tried the posted fixes but...
I had this exact error not to long ago. There was nothing in the book to help. I just finally changed my black ink cartridge. That stopped the error message.
So if you haven't tried that, put in new cartridges. Hope this helps.... :0)
Apr 26, 2009 | HP Officejet 5510 All-In-One Thermal...
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Remove and check color cartridge
the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
877 people viewed this question
Seeker5211
Seeker5211
