Question about Frigidaire Dryers
I have an frigidaire LEQ1442ESO front loader. It squeals when it turns. i need to find a manual that states how to open the unit to replace the bearings. Does anyone have a manual or has had this problem before and fixed it?
  • 15 Answers
SOURCE: broken stabilizer on Frigidaire front loader
IF it is the bottom stablizer it can be changed easily. But if it damaged the others or sub frame it could get costly.
Posted on Oct 10, 2007
  • 1294 Answers
SOURCE: Eurotech MA66 front loader user manual
Click on washing machines (below FIXYA )on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you will hv your manual on line. If available that is.
And rate me pl if helped............
Posted on Feb 08, 2008
  • 1028 Answers
SOURCE: Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Posted on Jul 08, 2008
SOURCE: My Frigidaire Affinity front loader smells like mold
Ours gets a musty smell because water gets trapped in the air-tight drum. I leave the door open in order to let the water evaporate. Also, the owners manual tells you to remove and clean out the soap dispenser drawer and the area that the drawer fits into. We have to do this monthly, as both get coated with black mold.
Posted on Jul 08, 2009
collegetutor
  • 125 Answers
SOURCE: ford festiva front wheel bearing worn out
I do have the manual and there are several on eBay all the time for Festivas, because I check there often for Festiva parts. They are often sold for about $20-$25 for the complete manual. You might want to try that. I have the manuals for Festiva, but I don't have a scanner, but I do have a digital camera that I could use to photograph it. I don't know if I can get your email address so that I can send the photos of the pages to you. Let me know.
Posted on Sep 12, 2009
Frigidaire front loader stops for a minute than spins,making awful squeak and when I moved think something broke and now the whole thing moves I found a piece of metal when I took the back off
Hello Tasha, thank you for your submission!
I understand that your Frigidaire washer stops for a minute then begins to squeal. I see in the picture you are looking at the rear bearing or spider arm on the back of the tub. I would recommend having a professional technician out since you stated that something may have been broken during moving or disassembly. This will help prevent any unnecessary part purchases. I hope this information is helpful. -Matt
Apr 09, 2016 | Frigidaire Washing Machines
I need manual for a frigidaire leq1442eso
Hey friend, thank you for the post!
I understand you are seeking the manual for your Frigidaire dryer, LEQ1442ES0. I have successfully located the Owner's Guide. This link should direct you to the information you are looking for. I hope this information proves useful. -Matt
Aug 25, 2014 | Frigidaire Dryers
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire FAFW4011LW front loader washer only select causal mode only. Please help. Thanks
Reset the unit by unplugging or turning breaker off to the unit for about 10 minutes. Then turn the unit back on. This is a hard reset. If this does not show any improvements you need a professional to diagnose the control panel/board for repairs.
Dec 21, 2012 | Frigidaire FAFW4011LW Washer
My frigidaire fron loader will not spin during wash cycle but will spin when placed on spin
If the drain pump is working correctly and you can get it to spin manually, then the board is faulty. Had the exact same problem with an Lg front loader 40 min. ago.(have to replace the board.)
Jun 14, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire top loader washer won't drain
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
May 31, 2010 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire Front Loader Washer will not turn on at all???
it came from your dispencer ..it activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Frigidaire front loader keeps filling!
You will need to have him replace the Water inlet valve it is located where the hoses connect to the unit.. it sounds like it is stuck open... one thing you can do first is to shut off the water remove the hoses and clean the screens inside the valve you will need a paper clip to pull them out blow into the valve there may just be a peice of something that was in your plumbing stick in there holding open the plunger if that does not work the valve may need replaced
Jan 26, 2008 | Frigidaire GLTR1670A Front Load Washer
Front loader
Click on Frigidaire (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
If u are not satisfied with the manual, click on 'thanks for trying', your prob will be back on the website.
Jan 15, 2008 | Frigidaire GLTR1670A Front Load Washer
Dryers Logo
90 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
