Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Coolin have a side by side refrigerator and its not coolin, makes clickin sound every 15 min
  • Whirlpool Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezercoolin - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 31, 2010
Testimonial: "THANK YOU SO MUCH FOR INPUT, IM GETTIN SOMEONE TO CHK IT OUT AS WE SPEAK. WILL LET U KNOW RESULTS SOON"
Transformer keeps blowing on the high side after about 15 Min? Have changed out many transformers and blower motor.
Replace the transformer with a 75va resettable transformer.
Check all wiring for a loose connection at the unit and the disconnect and the breaker panel.
Double check ground wires.
Check the low voltage side for a back feed short from a faulty component.
Could be caused from a bad thermostat wire.
Do a continuity reading on stat wires to look for a short.
Do an amp draw reading on the unit to determine an increase in amperage.
Jul 18, 2011 | Ruud UBHC Air Conditioner
HAVE A FRENCH DOOR FRIDE THATS NOT COOLIN AT ALL .FREEZER BELOW WORKS FINE.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrig is running, but freezer defrosted and food side seems to be getting warm. Always blew warm air from bottom front, now just cold air.
Sounds like the compressor is not running. Try unplugging for 15 min. to allow compressor to reset. If you hear a clicking noise you may have a bad main board.
Feb 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Arctica intermittant clicking sound, panel flashes "hrs"
It sounds like the main control board is going bad . This controls every part on the fridge , except for the light bulbs . It's located on the back of the refrig , behind an 8" X 10" panel , with about 11 screws , holding the panel on . Part number WR55X10656 .
Sep 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Ge profile is making a sound every 5 min. that sounds like a woodpecker pecking
unplug for about 15 mins, move it for about 1 foot from the wall then plug back.
Sep 15, 2009 | Refrigerators
Refrigerator does not get cold - both freezer and refrigerator section. I noted a clicking sound around the compressor area - turning on and off.
unplug and move refrigerator 1 foot from the wall. Wait 15 mins , plug again. If it works don't push refrigerator to the wall again let it stay at 1 foot from the wall. If it doesn't, call the technician who will test for you realay and compressor.
Sep 12, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ge side by side refrigerator has stop coolin on both sides
The clicking you hear is most likely the compressor trying to cycle. It sounds to me like you are low on refrigerant. Most are thermo. protected and will not run on low coolant. Frigerators DO NOT make cold, they absorb heat from inside the box and expell it out the back. Most common cause of refrigerant loss is a leak, usually near the compressor. Hope I Helped
Mar 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag MSD2756GE Side by Side Fridge
You have a bad compressor, time for a new refrigerator. Check your warantee for compressor failure. Might be 5 years.
Dec 31, 2008 | Maytag MSD2756G Side by Side Refrigerator
I have Samsung RS2545SH. Refrigerator make beep sound every 15 min. Can you please give me solution?
reset the refrigerator by holding in the two upper buttons unitil the display blinks. then it should reset and you should have everything working fine. please don't forget to rate the solutions when yopur question has been resolved. Thanks for using FixYa
Dec 04, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
87 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
