Question about Canon PowerShot S60 Digital Camera
Camera will not take a picture but previously taken pictures can be viewed
  • 1,170 Answers
If the camera is showing a black or distorted screen when set to photo, and photos that are taken with the black screen also show up black or distorted, then this would likely be a CCD imager failure, a common occurrence for your model camera.
If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include: A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Posted on May 31, 2010
  • 3 Answers
SOURCE: black screen when in picture mode cant take pictures
PER007 in solution #3 is correct.
  • Follow the URL: http://www.nikonusa.com/email_images/nikonusa/service_advisory/launch_all.html
  • Fill out the form
  • Mail in your camera if it's listed
  • Receive your working unit free of charge
I had the same problem with my CoolPix5400 and this resolved the issue.
Posted on Dec 23, 2007
Steve5
  • 423 Answers
SOURCE: fuji Finex 800 camera
If it's pink/purple and "streaky", you have a bad CCD sensor. The only fix is replacement of the sensor. This is the main image capturing sensor in the camera. The situation is well documented on the web. It's usually the end of the camera, unless it's under warranty (or just a little past). Approaching Fuji's repair department can sometimes yield a sympathetic rep who'll have it fixed at no charge to you. If you are on the hook for the repair, expect to drop about $100 US.
Posted on Mar 28, 2008
welcomejee
  • 10594 Answers
SOURCE: pictures are blurry blue/white colour with vertical lines
You camera has problem with CCD Imager.
Following Sony Official weblink might help you to get Free of Cost repair of DSC-T1 camera with problem in CCD Imager.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Posted on Aug 05, 2008
  • 919 Answers
SOURCE: write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Posted on Dec 15, 2008
welcomejee
  • 10594 Answers
SOURCE: pictures on LED screen are yellow, purple, red and blurred
It is bad ccd imager problem and ccd imager will be replaced in this camera.
Sony will repair free of cost DSC-T1 for ccd imager problem as per announced scheme. only $20 will be charged as shipment charges.
Click Sony CCD Imager Support for details.
Posted on Apr 15, 2009
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
SD CARD DOES NOT SHOW PICTURES ALREADY ON IT IN FUJI Z35
Your previous camera wasn't another Z35, was it? Most cameras will not display pictures that were taken with another camera. The old pictures are most likely still on the card. You can plug the card into a card reader and transfer them to a computer.
Mar 14, 2010 | Fujitsu Cameras
New pictures are black field. cant take new pictures
It is known problem of ccd imager failure in Canon A70 camera and ccd imager will be replaced to get live view in camera mode to take fresh pictures.
Canon offers free of cost ccd imager replacement for A70. Click Canon CCD Imager Advisory for details.
Thanks.
Mar 04, 2010 | Canon PowerShot A70 Digital Camera
I had Fuji S5000 for about 3 years. It worked fine. Now all sudden, I can't see any image when trying to take a picture. Both image through view finder and on LCD are just blank. Someone told me that a...
Hi
I have got an S5000 that I can still view previously taken pictures from the card, but when trying to take pictures the screen and view finder shows a peculiar distorted purple and green picture and any picture taken is just a green blur.
I contacted Fuji and they say they can repair it for £90 (about $120)
Nov 02, 2009 | Fuji FinePix S5000 Digital Camera
How do do view pictures taken?
press the little sideways arrow button. You then move to the next or previous image using the left/right side of the command dial on the back.
Aug 18, 2009 | Fuji FinePix S1000FD Digital Camera
Picture screen
You can choose whether or not to display the picture you have just taken on
the monitor.
ON : The picture being recorded to the card is displayed. This is useful for
making a brief check of the picture you have just taken. You can
resume shooting anytime during REC VIEW.
OFF : The picture being recorded to the card is not displayed. This is
useful when you want to prepare for your next shot while the
previous picture is being recorded.
1 In the shooting mode top menu,
select MODE MENU
 SETUP
REC VIEW  OFF or ON, and press
Jun 25, 2008 | Olympus Camedia C-350 Digital Camera
Camera won't take pictures w/new batteries
You should replace the camera with the identical battery as recommended. REfer to your manual for the browsing of the previously taken pictures.
User manual also will tell you how to replace the battery.
may this help, melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Apr 22, 2008 | Polaroid i531 Digital Camera
Canon PowerShot S60 Digital Camera Logo
230 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
