Question about Packard Bell iMedia SL 9553 (P660401806) PC Desktop
When ever I open a programme such as Itunes, My screen needs calibrating all the time, How do I stop this?
    Problem Solver:
  • 37 Answers
Well that will depend on what windows you're using.
Posted on Jun 01, 2010
Touch screen calibration
Press the keys listed below, please note you need to press the Clear/Stop key 5 times. The screen will change after entering the keys and touch screen calibration will be option number 1. The calibration will consist of pressing a couple of small circles on the screen.
Clear Modes->1-9-9-3->Clear/Stop(5 times)
or
Reset->1-9-9-3->Stop(5 times)
Feb 17, 2014 | Ricoh Aficio MP C4500 Copier with Print,...
Tip
How to calibrate the MSA Altair 4
Want to calibrate the MSA Altair 4 Gas Detector or MSA Altair 4X? Here's how:
1. Turn the MSA Altair 4 and MSA Altair 4X on in normal reading mode. Do this by pressing and holding the center button.
2. Once the MSA Altair 4 and MSA Altair 4X is in normal reading mode, you need to send it into calibration mode. Do this by pressing and holding right beeps at you and the screen asks you to zero the monitor (sensor refresh on the MSA Altair 4X).
3. Now that the screen is asking for confirmation, press the center button once to confirm. This will send the monitor into zeroing mode. Now is a good time to set the monitor down, and grab your calibration gas, regulator, and calibration adapter.
4. Open the valve on your regulator. This is a very important step so you do not ruin your calibration gas cylinder. Now screw it in to your calibration gas cylinder. Close the regulator once you hear gas spewing out of it. This is the signal to know your regulator is good to close. Continue screwing in the regulator until it stops. Do not overturn it.
5. Attach the tubing to the hose barb on your regulator. Make sure the tubing is also connected to your calibration adapter.
6. Wait for the screen to come up asking for you to apply calibration gas. Once this screen comes up, press the center button again to confirm. Screw the calibration adapter in to your gas detector. Once it is screwed on, turn on your gas.
7. Make sure your calibration gas values on the screen match what is on your calibration gas cylinder!
8. Once the calibration procedure is completed, turn your gas off and remove the calibration adapter from the MSA Altair 4 or MSA Altair 4X. The screen will go back to normal reading mode within a few seconds.
9. Congratulations! You have officially calibrated your MSA Altair 4 or MSA Altair 4X gas monitor. Make sure to record these readings in your calibration log!
If you come up with an error, the most likely bet is a bad oxygen sensor, but it could be a number of other issues. Feel free to email me.
on Sep 29, 2014 | MSA Altair 4 Multigas Detectors - 10085989
How do I calibrate my windows PC monitor?
To calibrate your screen you have to open the control panel by clicking on the start button then the control panel in the right collum. Type "calibrate display" into the search bar in the top right of the control panel window. Open the calibrator by clicking on "calibrate display color" you may have to have administrator permission to calibrate the screen. Then follow the instruction on the screen.
Oct 20, 2013 | Computers & Internet
Er 1 error
Dear Sir:
adjust the speed sensor, see the diagram attached, clean, and tight the connector very well.
2) Test the input voltage motor, if there are the motor need repair or replace.
3) Test the output voltage from the main motor board for the input of motor, if there are NOT, the board is faulty.
4) After fix it, run the software calibration, for diagnose, and troubleshooting.
sincerely. God bless you
Apr 24, 2012 | Avanti Exercise & Fitness
Error 3212
Macafee security center is the culprit.
Open Macafee then: select;
Internet & Network > configure
Firewall > Advanced
Programm Permissions > scroll down to Itunes
Highlight (click on)
Then Grant full access to Itunes.
APPLY then OK
When you select store from Itunes you will need to register with Itunes
Apr 17, 2011 | Apple iTunes
Malfunctioning keyboard. If touch a letter A a different letter will come up. same thing trying to use the calculater.
the screen needs calibration. below are the instruction on how to calibrate the screen. The Digitizer Preferences screen opens the digitizer calibration screen. This is the same screen that appears when you start your handheld for the first time. You can recalibrate your screen after a hard reset or if your digitizer drifts. You may need to repeat this process a few times until the calibration registers. To calibrate your handheld screen: 1. From the General Preferences list, select Digitizer. 2. Tap the targets as indicated on the screen as precisely as possible.
TIP You can also press Left, Right, Up, and Down on the navigator to highlight a Preferences screen name and then press Select on the navigator to open that Preferences screen.
Aug 04, 2010 | Palm Zire 71 Handheld
Lanier LD435c touch screen is not registering touch in right plac
Press the yellow clear modes button then press
1 9 9 3 and the red clear/stop botton 5 times
this will open up the touch screen calibration menu
select calibrate touch screen. follow on screen directions.
Good Luck
Apr 08, 2010 | Office Equipment & Supplies
How do I change the print head on a Xerox 8500?
How to remove a printhead
  1. Press the on-line / off-line key on the printer operator panel to set the printer off-line.
  2. Use the upper softkeys to scroll to the 'Replace printhead' card
  3. Press the softkey below the 'Replace printhead' card to enter the wizard.
    An introduction screen displays the message 'Use this wizard to replace printheads. A roll is needed for calibration.'
  4. Press the key for 'Next'.
    The screen displays the message 'Select roll to use'.
    The system does a calibration at the end of the wizard. You can only calibrate on the defined media types. When calibration is not possible with the media available on the printer, the system asks you to load the correct media. When calibration is possible with one of the rolls, the system automatically uses the correct media roll. When calibration is possible with both rolls, use the lower softkeys to select the roll to use.
  5. Press the key for 'Next'.
    The screen displays the message 'Carriage moving to centre position...' while the carriage moves to the centre.
    The screen displays 'Open top cover.'
  6. Open the top cover. The screen displays the message 'Replace printheads' and the printheads that you must replace. Find the correct printhead number on the printhead carriage.
  7. Press the front of the printhead cover to unlock the cover.
  8. Open the printhead cover.
  9. Pull out the printhead and remove it.
How to place a printhead
  1. Remove the protective tape from the new printhead.
    Do not touch the contact and nozzle areas of the printhead after you remove the protective tape.
  2. Place the new printhead in the printhead holder.
    The printhead only fits in one way.
  3. Close the printhead cover.
  4. After you replaced the defective printhead, press the softkey for 'Next'
  5. The screen displays the message 'Make sure that all head covers are properly positioned.'
    Press the key for 'Done'.
    The screen displays the message 'Close top cover.'
  6. Close the top cover.
    The screen displays the message 'Carriage moving to home position...'
  7. The screen displays 'Calibrating...'.
    The calibration process takes several minutes.
    You can stop the calibration process at any time. Press the key for 'Cancel' to stop the calibration process.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Sep 08, 2009 | Xerox Phaser 8550DX Laser Printer
Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Sep 06, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
Packard Bell iMedia SL 9553 (P660401806) PC Desktop Logo
21 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
