Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire top loader washer won't drain - Frigidaire ATF6000ES Front Load Washer
When the knob is moved to spin it still does not drain. Any advice?
Posted on Jun 04, 2010
    President:
  • 1,382 Answers
The timer has went bad in your front load washer.Thats the reason why the unit is not draining properly. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure. You should go for a replacement.
Thank you !!
Posted on May 31, 2010
Ltf2940fe
Hi Kimberly, this is AP. Thank you for your post.
I understand you are having trouble with your Frigidaire front load washer, model LTF2940FE, not draining or spinning. There are a few possibilities that could be causing this to happen.
Overuse of detergent can result in oversudsing then restricting the tub from turning properly and not spinning out. You can attempt running a cold water rinse cycle to get rid of suds if this is case.
Another possibility could be that the drain hose is too long or restricted. If the drain pump makes a humming noise there could be a restriction in the drain line. Confirm that your standpipe (located in the rear of the washer) height is not higher than 96" and not below 24". Lastly, if the drain pump does not make a humming noise once the washer is in the spin cycle a defective timer or drain pump could be the cause of your washer not draining or spinning
If you can determine that oversudsing, a too long or clogged drain hose is not the root of the problem I would recommend contacting an authorized technician. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts can be costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I have provided a link below that will assist you in locating and authorized technician in your area if needed. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
Mar 20, 2014 | Frigidaire ATF6000ES Front Load Washer
Why my frigidaire top loader wont spin?
Hi - Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have either the pump or timer diagnose.
Oct 18, 2012 | Frigidaire FEX831CS Top Load Stacked...
My top washer loader would not drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 04, 2010 | Frigidaire ATF6000ES Front Load Washer
Front loader washer -water comes and just goes
Your problem is water siphoning because of the drain pipe too low or no air gap where the drain enters the wall. The drain hose from the washer should be at least 33 inches high.
Apr 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
hi thanks for your question. it would appear to me that the problem is with your lid switch would check that first try it and let me know thanks THE APPLIANCE DOC.
Aug 04, 2008 | Frigidaire CWS3600AS Top Load Washer
Front loader
Click on Frigidaire (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
If u are not satisfied with the manual, click on 'thanks for trying', your prob will be back on the website.
Jan 15, 2008 | Frigidaire GLTR1670A Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire ATF6000ES Front Load Washer Logo
169 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
