Question about Garden
I have a Craftsman lawn tractor 18.0hp 42" mower. It will start fine but when I step off the clutch it cuts off.
  • 360 Answers
I think you did not step on the turtle very well before releasing the clutch, that's why it cuts off.
So, while you step on the clutch, match your turlte a bit, before releasing the clutch and you should gradually realease the clutch while you step on the turtle.
This problem is a minor one.
Take care.
Posted on May 31, 2010
My Craftsman 42" lawn tractor
I would suggest checking your owner's manual. There is a leveling process and my Craftsman wasn't leveled at the factory. Once I leveled mine, it cut fine. If you can't find it in your manual, google leveling craftsman mower deck.
May 14, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I just recieved craftsman lt1000, 19.5 b&s, 42 in. cut with hydrostat that was fine but I think I tripped a kill switch and it won't even try to engage the starter. What kill switches are there beside...
You didn't indicate what model number you have. You can download a manual here:http://www.managemylife.com/mmh/owner_manuals/21205/CRAFTSMAN-Lawn,-Tractor-L0306104?brand_name_search=917272672+CRAFTSMAN if the 917272672 isn't the right model go to www.searspartsdirect.com and enter you model number. When the parts come up look over on right had side of page for button to select manual. To start, you must have foot on clutch, PTO disengaged. The seat switch doesn't come into play until the PTO is engaged. Check for voltage at the B terminal on the start switch to be sure fuse is good. From there check the S terminal when you turn key to start. From there it goes to the clutch/brake switch (when depressed) then to pto clutch then to solenoid. GOOD LUCK!
Aug 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a deck diagram for a 19.5 hp 42' cut
Craftsman 42 in deck makes terrible noise and middle wheel shakes. started while mowing.
Jul 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Cuts out when I let out the clutch
try and find a relay, near the engine, which is connected to the safety switches attached to the seat and clutch/brake pedal. you may find that relay to be bad, or you need to replace or short the safety switches. If you short them, might be a safety issue as the engine and blades will run unattended. Seems to be a very common problem with craftsman lawn tractors.
Jun 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 14.5 hp 42" cutting grass just fine depressed clutch engine stopped can't start turns over just fine have spark & gas
Make sure that you have 12vdc at the carb solenoid. If you do, next check your compression. You can do this with a compression gauge or by taking the spark plug out and placing your thumb over the hole and turning over the engine. If you are building compression it will blow your finger off the hole. If not check your valves to make sure they have the right clearance.
Oct 27, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman lt1000 rider 42 in deck is stuck in gear and wont go into neutral. so i cant get it started.
this happens when lawnmower is cut off in gear try this mash clutch and shake mower forward and backwards while trying to shift into neutral
Sep 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
