Question about Whirlpool WED5700S Electric Dryer
I have a whirlpool electric dryer WED5700SWO...there is power going into it, but it won't start. Is there a reset switch? I was drying some very heavy towels. It stopped and won't start again. It's only 2 years old.
  • Whirlpool Master
  • 43,501 Answers
There can be many reasons why your dryerI have a whirlpool electric dryer - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on May 31, 2010
Testimonial: "Thanks, it seems that the thermal switch is what everyone is saying...I'll check it an get back to you :)"
Samsung dryer DV42h5000ew won't power up
Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Jan 02, 2017 | Samsung Dryers
417.84052500 electric dry 05 model safe mode code. Everything lights up but won't run
Rocky, Could be door switch problem.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Bypass dryer door switch Whirlpool
Dryer Not Starting How to Test the Door Switch
. Whirlpool Kenmore Dryer Repair 01 Won Start or Run Door Switch 3406107...
http://www.selfhelpforums.com/archive/index.php/t-10060.html
Mar 13, 2016 | Kenmore Dryers
Whirlpool dryer won't turn on can hear
The switch you speak of is a mechanical switch with electrical contacts. If the spring inside gets rusty, it doesn't turn properly....replace it!
Dec 26, 2012 | Whirlpool Dryers
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
Whirlpool dryer won't dry clotes Model# LER4634PQ1
Dear Sir:
Please see this possibles causes:
Power from the house
test for blown fuse or c. breaker tripped, change or reset.
Heating element
test for burn or open heating element see the video
Thermal fuse
test for open fuse, see the video
Wiring
test for burn or break wires. test for continuity.
God bless you
May 23, 2012 | Whirlpool LER4634J Electric Dryer
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer wed5700swo. only about 2 years old, not drying as good as it used to. think i blew a thermal fuse because the vent was clogged. there is a thermal fuse with 4 wires in the lower left...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 07, 2011 | Whirlpool Dryers
My whirlpool ler8648pg dryer has heat but not enough to dry larger loads. Takes multiple cycles to dry. Does anyone have a solution? Thanks
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 24, 2010 | Whirlpool LER8648P Electric Dryer
Dry won't start when button is pushed yes it has
Bad door switch, possibly. Wire slide connector on the door switch is loose, possibly. These are really simple to fix.
Apr 07, 2010 | Whirlpool WED5900S Electric Dryer
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WED5700S Electric Dryer Logo
356 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
