Question about Mazzer Coffee-grinder SUPER JOLLY Electric
Power on but will not grind beans - Mazzer Coffee-grinder SUPER JOLLY Electric
    Genius:
  • 1,417 Answers
Hello
Posted on May 31, 2010
  • Oloyede Monsuru May 31, 2010
    hello,
    what this means is that there have been a disconnection from the power supply to the grander it self what you need to do to fix up the problem is to unscrew the grinder and trace the wire which supply to the roller of the blade......
    Before i process, i will like you to answer to this question .
    is your grander making any sound when you put the power on from the power supply?
    if the answer to the question is YES then it mean there is a particle of the last use that is hooking it from rolling which will need to be remove,
    please before this assignment can be carry out all source of power supply most be off the grander but if your answer to the sound is NO it simply means that there is power failing from the roller which need connection
    to fix it up unscrew the grander and check up on the wires then replace them to there position by the roller it self.
    thank you and thanks for using fixya.
I have a saeco royal my machine is grinding beans but will not stop
Your question is not right.
Grinder stops on its own in 16 to 18 seconds (times out).
It may not be grinding beans an spinning free because the beans are not feeding.
You may have used oily beans or set the grind fineness at very fine powder like. This powder like fineness also clogs the grinder..
You need to clean the grinding chamber and the ground coffee outlet.
Dec 19, 2016 | Saeco Coffee Makers & Espresso Machines
Why aren't the beans being ground?
try pushing the beans into the grind mechanism while it is grinding or turning the grinder knob but only when grinding, or try different beans
Jun 10, 2014 | Saeco Incanto Classic Espresso Machine
The grinder runs but does not grind beans
Sounds like a blockage in the bean hopper. With the power off, take away the bean hopper and reach in the hole where the beans go and poke around to see if you can clear it.
Mar 03, 2012 | Miele CVA615 Espresso Machine
Beans are too oily
This fixes almost all the "beans will not feed or beans will not grind" problems caused by coffee bean dust packed in the burrs. Oily beans cause this problem more fequently.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured out. Use your shop vacuum to **** grounds out the spout and backward out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to a small setting like six and then open the settings all the way again. (The grinder will not start at a low setting with the rice in it. If you let it stop, open the settings to about 16 before trying to restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind. Grind until most of the rice dust is expelled (any remaining trace of rice dust will not affect the flavor of the coffee).
Aug 06, 2009 | Bosch Benvenuto B30 Espresso/Coffee Maker
Spinning but not grinding
Dec 08, 2008 | Cuisinart Supreme Grind CCM-16PC Grinder
Machine will not grind beans.
I had the same problem and Saeco recommended that I clean the grinder. Check this link for instructions.http://saecooutlet.com/instructions/Grinder%20Cleaning_Magics_Royals.pdf
Jul 15, 2007 | Saeco Royal Professional Espresso Machine
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Mazzer Coffee-grinder SUPER JOLLY Electric Logo
48 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
